Should be kind of obvious, but just to confirm: a 85mm lens will act like a 135mm on a crop body.
What about max aperture? If I have 50mm f/2.8, will it behave like 80mm f/2.8 or 80mm f/3.5?
uOpt Goldmember 2,283 posts Likes: 3 Joined Jun 2009 Location: Boston, MA, USA More info | Jan 14, 2011 16:08 | #1 Should be kind of obvious, but just to confirm: a 85mm lens will act like a 135mm on a crop body. My imagine composition sucks. I need a heavier lens.
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Jan 14, 2011 16:12 | #2 uOpt wrote in post #11641781 Should be kind of obvious, but just to confirm: a 85mm lens will act like a 135mm on a crop body. What about max aperture? If I have 50mm f/2.8, will it behave like 80mm f/2.8 or 80mm f/3.5? The aperture is a physical opening represented as a ratio of the focal length. The focal length is not actually changing (it's still 50mm) and neither is the aperture (it's still 50mm/2.8 or 17.85mm in diameter). You will still be delivering f2.8 light to the sensor no matter the crop factor. Taylor
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Jan 14, 2011 16:15 | #3 tkbslc wrote in post #11641806 The aperture is a physical opening represented as a ratio of the focal length. The focal length is not actually changing (it's still 50mm) and neither is the aperture (it's still 50mm/2.8 or 17.85mm in diameter). However, when comparing equivalence, the lens will give similar results as an 80mm f4.5 lens on FF when used at the same distance to subject. So in a sense, you do have an aperture crop factor. Only from a DoF point of view, exposure remains unchanged. Will | WilliamLiuPhotography.com
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Jan 14, 2011 16:17 | #4 themadman wrote in post #11641824 Only from a DoF point of view, exposure remains unchanged. Yeah, I edited my original post to hopefully make that more clear. Taylor
Jan 14, 2011 16:17 | #5 Hmmm, I thought that the "apparent aperture" would go down with the square, so from 2.8 to 3.5? 2.8 * sqrt(1.6) = 3.5? My imagine composition sucks. I need a heavier lens.
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | Jan 14, 2011 16:20 | #6 uOpt wrote in post #11641834 Hmmm, I thought that the "apparent aperture" would go down with the square, so from 2.8 to 3.5? 2.8 * sqrt(1.6) = 3.5? The aperture size is what's important here. As I mentioned, a 50mm f2.8 has a 17.85mm aperture. That's 80/4.5. You pretty much just multiply both the aperture and focal length by the crop factor for FOV and DOF equivalence. You are getting 80mm equivalent focal length, but your aperture is still only 50/2.8. Taylor
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 14, 2011 18:48 | #7 uOpt wrote in post #11641781 Should be kind of obvious, but just to confirm: a 85mm lens will act like a 135mm on a crop body. This is incorrect. An 85mm lens will always be and act like an 85mm lens regardless of the camera it is mounted to. uOpt wrote in post #11641781 What about max aperture? If I have 50mm f/2.8, will it behave like 80mm f/2.8 or 80mm f/3.5? The aperture settings of any particular lens will be identical regardless of the camera it is mounted to. If you have a 50mm lens mounted to a 7D and set it to f/2.8, you will have the same exposure intensity as if you put the lens (or any lens, for that matter) on a 5D and set the aperture to f/2.8 (as long as the shutter speeds and ISO settings are the same, of course). Skip Douglas
| Latest registered member is EBiffany 1592 guests, 96 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
