Thread started 15 Jan 2011 (Saturday) 02:09
190XPROB Tripod Level
LittleFish
Jan 15, 2011 02:09 |  #1
I just received my 190xprob tripod in the mail today, and to my disappointment, the tripod's built in level sucks. I have it perfectly level on the ground, but yet it's saying that i need to tilt it slightly to the right (or left, can't remember now), which is obviously incorrect. Are any of you 190XPROB owners facing the same problem? Honestly, the only flaw regarding the tripod that I can spot right now is the level. Everything else is working just fine. If you were in my shoes, would you guys replace it with a new tripod, or would you guys just keep it as it is?
|Canon T1i | 50 1.8 | 18-55 IS | 17-55 IS USM | Manfrotto 190XPROB and 498RC2 |
-Syed-
themadman
Jan 15, 2011 02:14 |  #2
How do you know it is perfectly level?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
A5forfighting
Jan 15, 2011 02:43 |  #3
Enjoy the rock solid build of a Great tripod !
The level on mine is the same as the one on my Grip head.
7D, S95, EOSM,
troutfisher
Gallery: 23 photos
Jan 15, 2011 03:01 |  #4
Whether or not the tripod is level is irrelevant,the important bit is to get the camera level and with a ball head the only way to do that is with a camera mounted level
Chris
" Age and treachery will always defeat youth and enthusiasm"
Overkill-F1
Jan 15, 2011 03:15 |  #5
I dislike not having the tripod level to begin with. I guess it's because I prefer a pan-tilt head. If the tripod isn't level, and you rotate the camera with the pan adjustment, the camera with go out of level horizontally.
...Terry
50D, 450D, 18-55mm IS, 30mm f/1.4, 60mm f2.8 macro, 100mm f2,
For Sale- EF 24mm f/2.8
There is a very fine line between "hobby" and "mental illness". Dave Barry
GooseberryVisuals
Joined Nov 2010
Jan 15, 2011 07:19 |  #6
I own a 190XPROB and I don't even look to see if my legs are level.
Having said that, I just bought a spirit level off ebay
MCAsan
Joined Jun 2010
Jan 15, 2011 08:03 as a reply to  @ GooseberryVisuals's post |  #7
My tripod has a spirit level. The RRS clamp on top of the ballhead has a spirit level....after all it is likely the clamp you want level...not really the trippod. And on top is my 7D which has internal level function. If I were using my 40D then I would have a spirit level stuck into the flash hotshoe.
Depending on the shot...single or several for a pano....you likely want the body level port to starboard (left to right). But you may or may not want the body level fore and aft (front to back). Have\ing levels on the tripod, clamp and camera body gives you the info needed to set up for your particular shot.
LittleFish
Jan 15, 2011 19:38 |  #8
after thinking about it for a bit, i think that i can probably live with the weird level on the tripod, as long as i get the hot shoe-mounted bubble level, since i'm going to be using a ballhead anyways. thanks. (:
-Syed-
johnf3f
Jan 16, 2011 21:01 |  #9
LittleFish wrote in post #11648661 (external link)
Got a Gitzo 2531. Using the spirit level on the tripod, the spirit level on the Manfrotto geared head and the spirit level on the Hotshoe - they ALL disagree - the moral is use the viewfinder!:eek:
Life is for living, cameras are to capture it (one day I will learn how!).
NinetyEight
"Banned for life"
Jan 17, 2011 14:29 |  #10
A level on a pair of legs is pretty useless IMO, on top the camera hot-shoe is where it's needed especially if you are using a ball-head.
Kev
LittleFish
Jan 17, 2011 14:42 |  #11
update: i just got my 498RC2 in the mail today and immediately mounted it onto the legs, and for some reason, the level is now functioning.(yay!)
How do i know that it is functioning? well i had all three of the legs fully extended on a flat and level surface (i.e. the floor). I checked the floor using a carpenter's level. (And yes, I found that the floor is perfectly flat). The tripod legs agrees with the carpenter's level. Therefore, the level on the tripod is now working. :P
i didn't know having a ballhead on top of the legs made that much of a difference in the reading.. interesting.
-Syed-
shaun ­ raney
Joined Jan 2005
Jan 18, 2011 09:31 |  #12
Thank god I saw this thread...I dropped my 190X legs and 804RC2 head and I thought for sure I bent something from the drop, the spirit level popped out of the head and I had to get a new one, I guess it's just a little off and its why my shots aren't panning right.
I was gonna go out and get a new head and try and pan, but this thread just saved me...now I can get a new head and a monopod! mwahahaha.
DIY PC with 34" Ultrawide | 7D | 24-105mm f/4 L IS USM | 50mm 1.8 | DJI Phantom 4
1,984 views & 0 likes for this thread, 10 members have posted to it.
Latest registered member is Fungus
1216 guests, 167 members online
