Thread started 16 Jan 2011 (Sunday) 04:21
help fixing colour in my wife's wedding dress
TCShadow
Jan 16, 2011 04:21 |  #1
Need to go from this
to this
preferably with lightroom. Anyone have a hint for me?
P.S. if you can't see the images, give it 30 secs I'm uploading them now.
Canon EOS 7D Canon EOS 40D + Grip
Canon 70-200mm f2.8L IS| Canon 24-70mm f2.8L | Canon 15-85mm IS |Canon 17-85mm IS | 580 EX II | Panasonic HDC-HS200
qczman
Jan 16, 2011 05:54 |  #2
Photoshop - Color Balance
Cyan to Red: -27
Magenta to Green: -26
Yellow to Blue: +36
tim
Light Bringer
Jan 16, 2011 20:07 |  #3
Jpeg or raw? Post the link to the original high res file.
With raw it's just a white balance and exposure adjustment, maybe tweaking the color slightly.
Redfish
Jan 16, 2011 20:31 |  #4
The sample is underexposed and the temperature is waayyyy to warm making it orange tinted. Cool the temperature down in LR and increase the exposure
good luck
Canon 1DXIII (2) Eos R 5R on the way 15-600 /1.2 - 5.6
6000ex's Bee's and boxes & PW's
RRS tripods and heads
TCShadow
Jan 17, 2011 16:31 as a reply to  @ Redfish's post |  #5
it's raw I'll post links to raw files later today.
tonylong
...winded
Gallery: 60 photos
Jan 17, 2011 16:42 |  #6
TCShadow wrote in post #11660641 (external link)
Have you tried the advice given so far -- brightening and adjusting the White Balance toward cooler, maybe the Blue or Purple saturation in the HSL panel? If so, how far have you gotten?
Tony
TCShadow
Jan 18, 2011 02:39 as a reply to  @ tonylong's post |  #7
If anyone else wants a go image is here (external link) (11mb)
TCShadow
Jan 18, 2011 02:41 as a reply to  @ TCShadow's post |  #8
I used the masked brush in lightroom and ended up just matching up the colour... I didn't see a way to cool the colour in the selection and if i did the whole picture it destroyed the skin tones.
I also sharpened the flowers and the little diamante pattern around the dress. Also increased clarity.
The camera missed focus unfortunately but it's the picture my other half likes best from the sequence. It looks pretty good unless you blow it up too big.
tim
Light Bringer
Jan 18, 2011 04:12 |  #9
IMHO it's just underexposed. The photographer exposed for the wedding dress, which is one school of thought, but since wedding dresses are reflective and have phosphors in them if you expose for the dress everything else is underexposed. My usual method is to expose for the face, then bring the dress back if possible.
The way to work with this is to selectively brighten the non-dress areas of the photo. You can do it in your raw converter (ACR does it) with the adjustment brush, don't know if DPP does. You can do it in PS in any number of ways, such as a brightness or levels layer with a mask so it doesn't affect the dress. Just use a soft brush around the edges of the dress.
TCShadow
Jan 18, 2011 17:35 as a reply to  @ tim's post |  #10
yeh i can give that a go too see what the result is.
Now that you mention it my wife has very light almost white skin so yes the picture is definitely underexposed.
Peano
Jan 18, 2011 17:52 |  #11
I don't do Lightroom. If you have Photoshop, it's a simple matter of placing a sample point and using curves to bring the RGB values up to those of your original sample. Takes about a minute.
HTTP response: NOT FOUND | MIME changed to 'image/jpeg'
Peano
RadiantPics.com (external link)
Peano
Jan 18, 2011 18:36 |  #12
See if this works.
http://img692.imagesha​ck.us/img692/7691/z9c9​7608x12.jpg (external link)
Peano
TCShadow
Jan 18, 2011 19:14 as a reply to  @ Peano's post |  #13
yeah definitely close bit too blue on the colour but I'll try your suggestion when i get home.
Thanks!
Peano
Jan 18, 2011 19:21 |  #14
TCShadow wrote in post #11668821 (external link)
Thanks!
If the rest of the image is OK (note the cloning in the background and extension of the canvas on the right, and leveling the image), it's a simple matter to select the purple part, open a curves adjustment layer, and make it less blue.
Peano
TCShadow
Jan 19, 2011 00:03 |  #15
Peano wrote in post #11668860 (external link)
wow i didn't even pick up all that stuff you did... i want your skills heh
3,052 views & 0 likes for this thread, 6 members have posted to it.
1436 guests, 109 members online
