rvdw98 wrote in post #11660472
Why do they list a car's maximum speed, when you're not allowed to drive that fast anywhere?
The fact that it can, doesn't mean that you must. Also, it's likely that the load rating is a design consequence rather than a goal.
Well... car enthusiasts go to tracks where you can if you want, and not many car manufactures actually advertise it unless it is a 180MPH + super car. But I guess point taken, so the max weight is more an indication of performance rather than something that will actually be applied.
So why can't the ball head hold a 400mm lens for example since it has such a massive weight capacity? Do manufacturers just like stating the weight capacity as a marketing "gimmick" (for lack of better word).
Edit: I mean weight should be directly correlated with all other forces on a ballhead, so if the ballhead can hold 60pounds, why can't I mount as big of a lens as I want on it?
