Thread started 18 Jan 2011 (Tuesday) 14:16
Recommend a firewall
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Jan 18, 2011 14:16 |  #1
Just got a new system - Win7 w/ 64 Pro.
Since rocks were formed, I've been using ZoneAlarm. But before buying a new ver, I would like to know if there is anything better nowadays.
I am not only concerned about incoming, but also outbound phone homes.
(Free would be a nice plus ;) :) )
Website (external link) |
digirebelva
Gallery: 376 photos
Jan 18, 2011 14:30 |  #2
I use Comodo on the same OS, works great for me..
bohdank
Jan 18, 2011 15:05 |  #3
Has Zonealarm ever failed you ? If not, why switch.
btw. I use Zonealarm.
Gaaaaa! DOH!! Oops!
Jan 18, 2011 15:21 |  #4
digirebelva wrote in post #11666964 (external link)
I'll take a look. However, I did the obligatory search before posting and found a few comments here on POTN about comodo trashing.
bohdank wrote in post #11667203 (external link)
Nope, it hasn't. Always served me pretty darn well, in fact. Guess I was hoping on something free.
e02937
Jan 18, 2011 15:23 |  #5
Windows 7's built in Firewall is pretty powerful.
Canon 7d
[15-85 IS] [70-200
f/4L IS] [I'm a PC]
[Full gear list and feedback]
MaxxuM
Jan 18, 2011 16:45 |  #6
Built in firewall, unless you're paranoid, then Comodo and stay in learning mode even if it wants to go to Safe Mode.
digirebelva
Gallery: 376 photos
Jan 18, 2011 17:55 as a reply to  @ MaxxuM's post |  #7
The built in firewall only protects agiangt incoming threats, if something has already gotten in, it wont alert you to a rouge program trying to connect out from inside.
mjmackinnon
Jan 18, 2011 18:35 |  #8
digirebelva wrote in post #11668368 (external link)
ERR.. No
Win7 has two parts to the firewall.
1. it blocks all network traffic unless it is within the allowed list. Both in and out.
2. as it's a system level app. even trying to make a change to it is under the sysadmin privilege so it brings up a dialog asking if you allow a change.
but the best form of firewall is using your own brain and not downloading and running programs that you don't know are safe. It's the free junk and pirate software roaming around on the internet that cause problems. If you just use clean software then you don't need to worry about Trojan apps.
Matt.
My Flickr (external link) - Canon EOS 5Diii | EF 50f/1.4 | EF 24-105 f/4L IS| EF 100-400L IS | EF 70-200f/4L |430 EX II | Elinchrom BX500Ri
Post Production: i7-2600k, Win7, iMac 27 i7 | Adobe Photoshop CS6
digirebelva
Gallery: 376 photos
Jan 18, 2011 20:11 as a reply to  @ mjmackinnon's post |  #9
So if a legitimate program wants to call home Win7 firewall is going to alert me? If so thats a major upgrade from past versions. which is good.
"If you just use clean software then you don't need to worry about Trojan "
Ever hear of a driveby infection through the browser..no action on your part needed..had it happen once...came through port 80 from an infected news site...fun stuff
MaxxuM
Jan 18, 2011 20:42 |  #10
digirebelva wrote in post #11669108 (external link)
No, Windows 7 will not block 'call home' software that is signed (via legitimate third party or Microsoft). Windows 7 will warn you about unsigned [Usually older] software if you try to install it - in which case, if it does want internet access, Windows 7 will ask you if you wish to allow it through. It isn't the safest methodology, but it's far less intrusive than more professional software/hardware which wants to make rules about every type of port activity (common end users would be ripping their hair out :D).
Also, most firewalls will not block anything coming over port 80 (or 8080) because it doesn't know good from bad - all it knows is port, yes and no. Your antivirus software should be scanning open ports for bad data (that isn't encrypted). Many AV packages now include web, email and other common ports for malware.
Windows 7 now comes with multiple layers of protection, most of which are beyond the scope of this thread. However, the key thing is that it knows the difference (if you answered correctly during setup) what type of network you're on and how much security to enable. If you are paranoid, go with Public Network vs Home. It will close off many common ports and enact rules that will prevent the majority of threats that exist out there. Doing so will involve some tweaking if you use things like torrent downloaders, some games that use odd ports and perhaps an app or two. Enabling Public will also kill many network functions of which you'll have to enable yourself later.
Like I said, get Comodo if you want a more advanced firewall. It's overkill really, but if you share large networks (colleges for instance) and know what you're doing (getting Windows services to work through a firewall if you do exist on a large network), then go for it. For me, ZoneAlarm is a bit twitchy. It's a PITA if you want to use some software packages or you have third party software that wants access to the TCP/IP stack.
solara
Jan 18, 2011 21:07 |  #11
I use ZoneAlarm - nice easy interface to control exactly which programs can do what.
I haven't tried to do it myself, but I've read that it's more cumbersome to set up Windows 7 firewall to control outbound controls.
If you only want the Firewall version without anything else, the ZoneAlarm firewall is still free:
http://www.zonealarm.c​om …ecurity-free-firewall.htm (external link)
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jan 18, 2011 21:16 |  #12
Win 7 firewall is good enough for me.
Bob
Gaaaaa! DOH!! Oops!
Jan 19, 2011 16:25 |  #13
How about Bit Defender? Anybody use it? I just read a review (external link) that sounded really good. (Unfortunately, it sounded so good it read like a sales flyer, but who knows.)
kjonnnn
Jan 19, 2011 16:25 as a reply to  @ Picture North Carolina's post |  #14
AVG?
malam
Jan 19, 2011 17:39 as a reply to  @ kjonnnn's post |  #15
I just switched from Zone Alarm to ESET Smart Security 4. Was on sale at my local Best Buy.
Canon 5D Mk III
EF70-200mm f2.8L IS MKII; EF50mm f1.2L; EF16-35mm f2.8L II; EF100mm f2.8L IS Macro; EF24-105mm f4.0L IS; EF200mmf2.8L II USM
3,133 views & 0 likes for this thread, 12 members have posted to it.
1635 guests, 100 members online
