Is it worth the upgrade from the 40D to 60D for better high ISO performance? With my 40D, the noise becomes too much at above 1000. Will my images be usable at ISO 1600 with the 60D?
Jan 18, 2011 14:18 | #1 Is it worth the upgrade from the 40D to 60D for better high ISO performance? With my 40D, the noise becomes too much at above 1000. Will my images be usable at ISO 1600 with the 60D? 5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
Immaculens creeped by the TF.... More info | Jan 18, 2011 14:50 | #2 eaglefan wrote in post #11666878 Is it worth the upgrade from the 40D to 60D for better high ISO performance? With my 40D, the noise becomes too much at above 1000. Will my images be usable at ISO 1600 with the 60D? ISO 1600 on the T2i/60D/7D is almost silk-like*
Mark-B Goldmember 2,248 posts Likes: 10 Joined Jul 2007 Location: Louisiana More info | Jan 18, 2011 15:00 | #3 There's no standard answer for that. You would hope that with each generation of camera and better software & sensors, than noise levels would improve, but all the conditions at the exact second you press the shutter play a big part. Mark-B
Immaculens creeped by the TF.... More info | for what its worth - here is an ISO 5000, processed in Lr3 with 'Fill Light" pushed to 61, with RN for anyone familiar with Lr. I assume this surpasses ISO6400 but not sure.
JeffreyG "my bits and pieces are all hard" More info | Jan 18, 2011 16:49 | #5 From what I've seen the T2i / 60D / 7D are the first significant step forward in 1.6X sensor noise control since the 20D. They do indeed seem to be quite a bit better. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Jan 18, 2011 16:54 | #6 my 7d is much better at higher iso's than my old camera (40D) Canon 5D MK3.... lenses -Sigma 35mm art. 135L
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Jan 18, 2011 17:04 | #7 eaglefan wrote in post #11666878 Is it worth the upgrade from the 40D to 60D for better high ISO performance? With my 40D, the noise becomes too much at above 1000. Will my images be usable at ISO 1600 with the 60D? you can compare ISO performance among different DSLR models here
gcogger Goldmember 2,554 posts Likes: 1 Joined Mar 2003 Location: Southampton, UK More info | Jan 18, 2011 20:46 | #8 JeffreyG wrote in post #11667988 From what I've seen the T2i / 60D / 7D are the first significant step forward in 1.6X sensor noise control since the 20D. They do indeed seem to be quite a bit better. People who liked the older 1.6X bodies to ISO 800 will probably be happy to ISO 1600. I concur - that's exactly how I see the situation. Graeme
District_History_Fan Goldmember 2,286 posts Likes: 1 Joined Dec 2008 More info | Jan 18, 2011 21:19 | #9 Mark-B wrote in post #11667166 There's no standard answer for that. You would hope that with each generation of camera and better software & sensors, than noise levels would improve, but all the conditions at the exact second you press the shutter play a big part. Personally, I could never say that noise levels are too much at any fixed level. ISO 3200 outside in daylight might look better than ISO 800 inside by candle light. ISO 1600 in a dark theater will look different when the spotlights are on than when they are off. When I go back and look at my pictures, I can pick out a few ISO 3200 shots from my 20D that are better than ISO 1600 shots from my 50D. All depends on the environment and technique when shooting. Generally speaking, I am pretty happy using auto ISO (100-1600) on my 50D and I frequently use 1250. The images look fine to me, but I don't go out of my way to look for noise. I either print them anywhere from 5x7 to 16x20, or I look at them in "fit to screen" mode on a 24" monitor. ISO performance wasn't really a consideration for me when upgrading from a 20D to 50D, and it probably shouldn't be when going from a 40D to 60D. I think the major differences lie elsewhere and you will be able to find faults at pixel level if you really go looking for them. Words of wisdom...
shoturtle Goldmember 1,187 posts Joined Oct 2010 Location: NYC/Frankfurt A.M. More info | Jan 18, 2011 21:50 | #10 Here is the 60d at 3200iso and the crop. It is much cleaner the my T1i up there. Traveling is my passion, so I am a major Frequent Flyer.
Genome Goldmember 1,000 posts Joined Dec 2009 More info | Jan 19, 2011 10:40 | #11 there are so many factors its almost impossible to get clear picture of what will work better.
Emmy ISO 12800
Oscar 12800 ISO 3 Flickr
Jan 19, 2011 10:56 | #12 Thanks for your replies and examples everyone. To answer Genome's question, I do shoot in RAW. I'm wondering if I would see less noise in the 60D RAW files than the 40D ones, assuming the settings are the same. 5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
Genome Goldmember 1,000 posts Joined Dec 2009 More info | Jan 19, 2011 10:59 | #13 no because the noise reduction in programs is better than any in camera noise reduction because you have complete control. Not to mention things like photoshop allow you to apply noise reduction selectively to areas that need it only. Flickr
shoturtle Goldmember 1,187 posts Joined Oct 2010 Location: NYC/Frankfurt A.M. More info | Jan 19, 2011 11:52 | #14 With the jpeg and raw thing, it depends. The in camera NR has gotten allot better. And NR programs work great on JPEGS also. So it depends on what you want to do. I shoot mostly jpegs, Raw files are huge, and the modern editing programs like photoshop and aperture 3 does a very good job on them. Even with WB. Traveling is my passion, so I am a major Frequent Flyer.
hieu1004 Goldmember 3,579 posts Likes: 4 Joined Jul 2010 Location: Seattle More info | Jan 19, 2011 12:06 | #15 It's all about nailing the exposure. With a 60D, you'll be able to use those higher ISO without an issue if you get the exposure right. ISO 1600 will be a piece of cake on a 60D. By utilizing HAMSTTR and exposing to the right, you'll be able to mitigate noise... Here are some examples on my 7D (similar to the 60D) at 6400 and 12800:
ISO 12,800
| Latest registered member is griggt 670 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
