Thread started 18 Jan 2011 (Tuesday) 19:17
Focus with 7D in timelapse/interval shooting
ToferPhotography
Joined Dec 2004
Jan 18, 2011 19:17 |  #1
Hi gang, I am having trouble with maintaining the Focus with 7D in timelapse/interval shooting. What settings do you normally use?
I turned the focus on the lens to MF (Manual) but not sure which camera setting to use? I am shooting in P.
Thanks!
Chris... Aka.."Tofer" ~ Canon EOS 7D 18-135 3.5IS / GoPro Hero 4 / Canon 50mm 1.8F / Rebel XT (350D) ~ Tamron 17-35mm SP AF 2.8 ~ Sigma 28-300 F3.5-6.3 DG Macro // Canon 75-300 zoom // Canon 430ex // - (Samsung Note4) - Lowepro Slingpack ==> :cool: Facebook (external link)
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Jan 18, 2011 19:23 |  #2
Depends on what you're trying to capture. If you want the camera to meter/expose for you, then you probably should set it at least to Av so that you can keep the aperture constant. The camera will then adjust the shutter speed (and iso as well if you set it to auto, though I wouldn't recommend auto iso).
You can manual focus first.. or AF at the spot you'd like to be in focus, then switch the lens to MF so it doesn't change, and voila.
Julian
highstakes
Jan 18, 2011 19:55 |  #3
I usually use AV-mode, then use manual focusing with the help of Canon's software.
Canon 5D II - Canon 16 - 35 f2.8L II - Canon 70 - 200 f2.8L IS II - 430EX II
ToferPhotography
Joined Dec 2004
Jan 18, 2011 20:47 as a reply to  @ highstakes's post |  #4
Thank you, I hadn't thought about the AV, focus THEN go to MF!
3,031 views & 0 likes for this thread, 3 members have posted to it.
921 guests, 118 members online
