Thread started 18 Jan 2011 (Tuesday) 22:15
My Camera Raw Techniques
dwpolette
Jan 18, 2011 22:15 |  #1
I had some spare time so I thought I would show a good comparison of what is possible when shooting in raw to really make your images pop, or at least a good starting point before diving deeper to retouch.
I'm sharing what I know, please keep in mind everyone has different styles and processing techniques.
First picture is SOOC with no sharpening. Second picture is with minor adjustments in camera raw, auto contrast and smart sharpening.
1 - SOOC.
IMAGE: http://farm6.static.flickr.com/5205/5369140454_5f6e7cbeee_z.jpg
IMAGE LINK: http://www.flickr.com …tephotography/5​369140454/  (external link)
SOOC (external link) by Dave Polette Photography (external link), on Flickr
2 - After Edit.
IMAGE: http://farm6.static.flickr.com/5205/5369140388_b15d909a4a_z.jpg
IMAGE LINK: http://www.flickr.com …tephotography/5​369140388/  (external link)
RawEdit (external link) by Dave Polette Photography (external link), on Flickr
So what did I do?
Step1. Open Image in Camera Raw
Step2. Adjust Temperature Control Slider.
I usually make this warmer to suit, keep a close eye on the skin tones you don't want to go too far and turn people yellow.
Step3. Recovery Slider.
Make sure that your highlight clipping warning is turned on. If its turned on, any areas that are over exposed and contain no detail will be red. To turn this on, goto the top right hand corner of the camera raw window in the histogram box and click on the black triangle. It will have a white box around it when turned on.
Adjust your recovery slider to reduce as much of the clipping red areas as possible.
Step4. Fill Light Slider.
In the above picture I set fill light to 25. Play around with this setting. This does the opposite to the recovery slider, it brings out more detail in the blacks, this is important because in the next step we are going to increase the contrast by adding more blacks and we don't want to lose any detail.
Step5. Blacks Slider.
Adjust this forward until you start losing detail in the dark areas, this will depend on how much fill light you use so keep playing around with both until you get the effect you are after. My setting was 18+, It should make the colours really start to pop.
Step6. Clarity Slider.
The clarity slider adjusts the mid-tone contrast. Its good for bringing out detail, I only use a little. For this photo I used 10+.
Step7. Vibrance & Contrast.
These again will depend on personal taste, for the above photo I used 5+ for each.
Step8. Open into Photoshop.
Once you are pretty happy with the image click the open button to open the image into Photoshop for the final touches.
Step9. Auto Contrast.
I find I never really get the contrast perfect in Camera Raw, so I use the Auto Contrast from the Image menu in Photoshop. It doesn't work with all images but for the above image it just brightened it up slightly.
Step10. Resize.
Most of my images go on the web so the second last step is to resize the image, i usually go for around 800 pixels wide.
Step11. Sharpen.
Always make sure you sharpen at the resolution of the final image. I use smart sharpen from the Filter -> Sharpen menu. The settings for this image were Amount 20%, Radius 1.0, Remove: Lens Blur. Be careful not to over sharpen, if you share you images with flickr they will have some additional sharpening added to them once uploaded so keep that in mind.
Thanks for reading. Please feel free to add to what I've already said and also for those much more knowledgeable than me, correct my mistakes.
Dave
5dMKII gripped, 24-70 f/2.8L, 85 f/1.8, 70-300 f/4 -5.6 IS
Flickr (external link) | Website (external link)
| Couch Photos (external link)
Alex.K
Jan 18, 2011 22:27 |  #2
thanks for posting! I just started shooting RAW, and am trying to figure out all that I can do with it. (:
website (external link)
facebook (external link)
365/The Last Year project (external link)
surgeonhawkeye
Gallery: 43 photos
Jan 19, 2011 09:13 |  #3
Thanks fot the tutorial!!
I love this
snyderman
Jan 19, 2011 12:15 |  #4
Dave,
We 'Daves' must think alike. For quick down and dirty edits, you described nearly my EXACT workflow! What I like most about your recipe is that it's quick. Total time between pulling a raw file into ACR then into photoshop completed and saved is about 2 minutes per image. It's what I use on all my sports shots.
dave
Canon 5D2 > 35L-85L-135L
s0lemunchies
Jan 19, 2011 12:39 |  #5
I love the natural feel to your post processing, thanks for sharing!
#NT / ISS / Zilvia
The name's Jon, aliases include solemunchies/zooopreme
FLICKR (external link) | TWITTER (external link)
nismogtr
Jan 19, 2011 12:47 |  #6
Thanks for sharing!
ProjectNineFive
Joined Jun 2010
Jan 19, 2011 23:26 |  #7
Would shooting a grey card to begin with give a similar result of the edited picture?
Project Nine Five Photography (external link)
My Facebook Fanpage<----ADD ME (external link)
dwpolette
Jan 20, 2011 01:58 |  #8
A Grey Card is only going to give you correct colour temperature (step2).
Dave
hegi
Jan 20, 2011 03:54 |  #9
Thank you for contributing inside into your raw workflow - this is really helpful.
7D · 50D · SIGMA 30MM f/1.4, CANON 85MM f/1.8, CANON 17-55MM f/2.8, CANON 70-200mm f/2.8 IS · SPEEDLIGHTS, ELINCHROM SKYPORTS AND OTHER LIGHTING STUFF · MANFROTTO 055XPROB, 488RC2 · LOWEPRO Classified Sling 180 AW · FLICKR (external link) · WEBSITE (external link)
alabama1980
Jan 20, 2011 10:20 |  #10
Thanks for sharing.
Name's Andy! :)
Facebook (external link)
My 500px (external link)
asheltonphoto.com (external link)
NGC2141
Jan 20, 2011 15:24 |  #11
Thanks for the post!
USMC - Semper Fidelis
orbitechgr
Jan 20, 2011 15:32 as a reply to  @ NGC2141's post |  #12
Thanks for sharing. Good post
Gear
Jim
IVOlution
Jan 20, 2011 16:42 |  #13
Awsome that you took the time to explain your work process!!
Cheers & THANK YOU!!
my.com (external link) - my Flick (external link)r - my FB (external link)
Show me what you do at night! --- Got water? post here!
3,312 views & 0 likes for this thread, 12 members have posted to it.
Latest registered member is RawBytes
1476 guests, 163 members online
