Thread started 19 Jan 2011 (Wednesday) 00:39
PC sync with 430 EX II
Mchphotographer
Joined Nov 2010
Jan 19, 2011 00:39 |  #1
I have a Canon EOS 40D and a 430EX II. I want to use the flash off camera with a PC sync cord. The 430 EX II doesn't have a PC sync port on it. Does this device (external link) connect to my flash and enable me to connect it to my camera via a PC sync cord?
Does my question make sense?
Any other thoughts are welcome!
Thanks!
40D with grip, 70-200 2.8L, 28-135 IS, 50 1.8, 18-55 IS, 430EX II, Sigma 500 DG Super
My Flickr (external link)
RafaPolit
Joined Jun 2005
Jan 19, 2011 01:03 |  #2
I have no idea if that adapter will work at all.
I have 'other thoughts' though :) :
There are two more or less inexpensive ways I know of to achieve off flash photography:
- One is to purchase a E-TTL off camera cord like this one: E-TTL Cord (external link). The reports say its a bit frail, there is a Canon version for around $50 or so.
- The other option is to purchase some of the wireless transmitters. I personally own the Young-Nuo ones featured here: Flash Trigger (external link), and it works great. Cowboy Studio also has some which are fairly cheap.
I prefer the second option as it is not physically constrained and you can place the Flash most anywhere. Of course, its not $7 as your option, but I have no idea if that will work.
Hope this helps a bit,
Rafa.
Rebel T2i | EF-S 17-55 IS | EF 70-200 f4L | EF-S 10-22 | 430EX II |
Picture Galleries at:
www.rafaelpolit.com (external link)
Mchphotographer
Joined Nov 2010
Jan 19, 2011 01:32 as a reply to  @ RafaPolit's post |  #3
I actually have both the ettl cord and the eBay triggers. My reason for wanting the Pc sync is that when using my flashes on the eBay triggers with umbrellas, the flash sits too high to really work effectively with the umbrella. So what I'm wanting to do is connect the eBay triggers to the flash via Pc sync cord so that I don't have to have it under my flash - holding it up an extra 4".
Thanks for the ideas though, Rafa!
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jan 19, 2011 01:49 as a reply to  @ Mchphotographer's post |  #4
That looks like it should do what you're expecting it to do; but I don't see how it's going to get around the problem you were describing about the height. It sits under your flash just like the mount on the off-camera cord mentioned earlier...
Also, you're not desiring E-TTL functionality, right?
Mchphotographer
Joined Nov 2010
Jan 19, 2011 10:34 |  #5
I just want to reduce the height under the flash - the wireless receiver is 4", and this other deal is about 1". And for what I'm doing, I don't need ettl.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 19, 2011 10:37 |  #6
take a look at www.flashzebra.com (external link) Lon, the owner is a member here, he can fix you up. He ships quick and stands behind his products.
DazJW
Jan 19, 2011 10:40 |  #7
What wireless receiver are you using that is 4" high? Mine are about an inch.
I think what you've linked will work but I'm not 100% on whether it's to fire a flash from a PC or convert a camera hotshoe to a PC connection. Though if it's just closing a circuit I suppose it should work both ways.
Mchphotographer
Joined Nov 2010
Jan 19, 2011 10:46 |  #8
I just ordered the adapter on ebay. I'll post a pic of my setup when it comes.
Mchphotographer
Joined Nov 2010
Jan 19, 2011 10:55 |  #9
This is the wireless system I'm using.
http://cgi.ebay.com …K:MEWNX:IT#ht_4​345wt_1141 (external link)
amfoto1
Jan 19, 2011 11:24 |  #10
Most wireless and PC sync adapters will only allow you to fire a manually set flash, without any TTL metering or camera-based control of the flash's output.
An off-camera-shoe-cord allows you to use full eTTL control of the flash. An ST-E2 or the camera models with built-in wireless control do, too, wirelessly and with the ability to control multiple flashes. But an ST-E2 (or the camera models with built-in wireless flash control) only work line-of-sight because they rely upon IR for communication. Why is this important? Well, line-of-sight significantly limits where you can position the flash and makes it more difficult to avoid hot spots or accidentally getting the flash in your image.
There are a few radio wireless with some sort of eTTL control starting to appear on the market (I think Paul Buff makes one, but suspect they're still pretty pricey). To do this, these have to translate the signal to radio, which doesn't need to be line-of-sight, then back to IR.
DazJW
Jan 19, 2011 11:29 |  #11
Why is everyone banging on about ETTL? The OP said they don't need it.
Mchphotographer wrote in post #11672258 (external link)
That's very weirdly orientated, but can't you turn it 90 degrees about that mounting brackt so the flash points along the umbrella shaft?
Steezy303
Gallery: 41 photos
Jan 19, 2011 11:34 |  #12
http://www.flashzebra.​com/hotshoes-shoes/0065.shtml (external link)
Joe Site (external link) Canon R3, Canon R6m2, Canon 1d mIII, Canon 500mm F/4L, Canon 135mm F/2L, Canon 70-200mm II F/2.8L Sigma 85mm F/1.4, Canon 50mm F/1.4, Canon 35mm F/1.4L, Tamron 24-70 F/2.8 DI VC, Helios 44-2
AntonLargiader
Jan 19, 2011 12:21 |  #13
Wow, those things are huge. I can't imagine why they are oriented the way they are. My PocketWizards add less than an inch, which is about the same as a cord adapter or the PC adapters shown (which look like they would do the trick). But can't you connect the triggers to the flash with the ETTL cord you have?
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
Mchphotographer
Joined Nov 2010
Jan 19, 2011 16:37 |  #14
@DaxJW I could do that, but it puts the flash head way too close to the umbrella.
@AntonLargiader Boy, do I ever feel stupid. Thanks!
Does anyone know how good the YongNuo YN-460 (external link) is? I'd just be using it as a slave...
2,500 views & 0 likes for this thread, 8 members have posted to it.
855 guests, 170 members online
