tonylong wrote in post #11672722
Well, you have Lightroom so there is not a
need to update Photoshop since Lightroom has the Raw processor that is in CS5 -- you can process you Raw files in Lightroom then just use the Edit in Photoshop function if/when you need to.
Miqs wrote in post #11672783
As I understand it, that is incorrect. Yes I can open the CR2 raw files in Lightroom 3 but I cannot edit them direct from LR to Photoshop CS4 in native format. Only if I convert to tiff or jpeg which I don't want to do at this stage.
You have to choose your workflow and determine your tools accordingly. If you prefer to be "Photoshop centric" then you either convert to DNG, update Photoshop, or use the Lightroom Save Metadata to File, in which case Bridge and Camera Raw can read an xml "sidecar" file and should be "mostly" compatible with LR3 edits.
With me, I use LR for all my Raw processing, and only open a file in Photoshop when the Raw processing is done and I actually need to do Photoshop work on it, which is not often. This works very well -- the image opens in Photoshop as a 16 bit tiff and I can do whatever to it and the tiff "project file" is automatically included in my Lightroom library.
The times I may go to open a file in Camera Raw through Bridge is when I'm doing a special project that would benefit from that approach, such as when I want to use the Photoshop Merge tools for something, although even for those you can open multiple files in Photoshop from Lightroom and then run the Merge tools (or HDR or whatever), so it's just a workflow question. If I do want to use Bridge for this type of thing it's simple to use the Write Metadata to File operation.
