Thread started 19 Jan 2011 (Wednesday) 10:51
Pano problems with Elements 8
irishman
Jan 19, 2011 10:51 |  #1
I keep getting a wierd error message when trying to do pano's in PSE8. Do you have to convert your images to JPEG from RAW before you load them?
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
ssim
Joined Apr 2003
Jan 19, 2011 11:27 |  #2
I don't use Elements and am not sure if this works the same as it does in CS5. In Bridge you can select the files that you want to use and then go to Tools-Photoshop-Photomerge. This will do the conversion for you and open the files. If you are doing it from inside of Elements or Photoshop you would need a file that is editable which requires conversion. What exactly is the error message that you allude to.
anamorph
Jan 19, 2011 14:30 |  #3
irishman wrote in post #11672232 (external link)
Yes. (or TIFF). It won't stitch RAW files. What's the error message BTW?
Elements can now and then go bananas with the pano option and it needs 'reset'
EOS 450D
EFS 18-55IS EFS 55-250IS EF 35 f/2 EF 50 f/1.8 EFS 60 f/2.8 Macro
goldboughtrue
Jan 19, 2011 23:57 |  #4
When I open images in PSE 8, it first goes through Camera Raw forcing it to convert to JPG before I can stitch a pano.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
tonylong
...winded
Gallery: 60 photos
Jan 20, 2011 00:28 |  #5
goldboughtrue wrote in post #11676609 (external link)
That's normal and necessary. Photoshop can't process a Raw file until it's converted to an image file. So, in Camera Raw you can ensure that all your settings are good and then go ahead into Photoshop and do the Pano. Or you would convert them individually and save them and then run the auto pano operation.
Tony
irishman
Jan 20, 2011 10:31 |  #6
Thanks for the info. Looks like I need to convert them first.
irishman
Jan 21, 2011 13:55 |  #7
Still doesn't work. Here is the error message that I get:
Error 1: Unable to create
Window-OS error [1400]
Line 364
-> var w=new Window (res);
That's it verbatim. WTH?
tonylong
...winded
Gallery: 60 photos
Jan 21, 2011 16:50 |  #8
Well, not having Elements I can't check. Are you doing this uusing jpegs or tiffs? If you are using tiffs you would want to ensure that they are 8 bits probably because some Elements stuff won't work with 16 bits. If, though, you're trying this with jpegs, then I wouldn't have a clue.
Tony
1,071 views & 0 likes for this thread, 5 members have posted to it.
2717 guests, 143 members online
