Thread started 20 Jan 2011 (Thursday) 10:21
can someone check this for me? (color check)
x0SiN0x
Jan 20, 2011 10:21 |  #1
*edit*
Think I figured it out, though need to research how color management is working within windows vs my mac.
Seems the small version didn't take the embed srgb profile option, so looked really off on all my windows machines and even worse in IE.
thanks all for the input, i was looking at the wrong place the whole time. But after some verification of color i was put on track to find it out (also that link PhotosGuy provided hinted me off to what it was)
*/edit*
I processed this image on my laptop (what I think is calibrated monitor, but now not sure - used a spyder3). this image loads fine on my laptop but on all my other computers (albeit not calibrated) they all show a hint of green in this photo and on the iphone/ipad its almost a pale color as if shes sick.
Can you let me know if the skin tone looks good on this image? Either my laptop is totally off or all my other monitors have the same level of bad color :(
*click for larger*
x0SiN0x AKA Tony - SiN is a (video) game name, nothing more!
Still learning (yes, newb) like some of you here, so please take any recommendations/opinio​ns with that in mind.
-[SmugMug (external link) | Gear | Feedback]-
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jan 20, 2011 10:53 |  #2
I'M ON MY LAPTOP, too, & the skin tones look a tiny bit pink. As a rough check, have you checked to see what the RGB values of a known white or gray in the image read? They should be pretty close.
Or try using a "standard" file? See the PDI_Target_AdobeRGB.jp​g test files at the bottom of:
http://www.gballard.ne​t/psd/srgbforwww.html (external link)
Rubi ­ Jane
Joined Nov 2005
Jan 20, 2011 11:07 |  #3
On my MacBook I'd see the tiny pinkish in the skin tones like Frank. I'll check on my calibrated desktop when I get back to it shortly.
Lindsey
Gear - Website (external link)
TTk
Jan 20, 2011 11:17 as a reply to  @ Rubi Jane's post |  #4
A hint of red on the face from my cal' screen.;)
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
x0SiN0x
Jan 20, 2011 11:24 |  #5
PhotosGuy wrote in post #11678731 (external link)
As I look at it again on my laptop I can see maybe a hint of pink. so that's at least closer to what i'm seeing vs all my other monitors. I did a gray card and tried out the colorchecker passport in the same test session (was just playing around with new backdrops)... but then went into photoshop to play around with settings, could have pushed something a little too far with the reds.
I did however change from adobergb to srgb in photoshop. Never seen that pop up when I went to save from photoshop (do 99% of my work in lightroom), used to it just saying "embed srgb profile" - maybe I messed it up there too and my other computers are not seeing it or liking something with it... not sure, this is the first time ive ever really had that bad of a color shift from computer to computer - what really threw me off was all my other monitors were similar in color vs my "calibrated" display
im going to check out those images on the link provided, thanks never seen that before.
thanks!
ChasP505
"brain damaged old guy"
Jan 20, 2011 11:57 as a reply to  @ post 11678988 |  #6
One problem viewing it through a non-color managed browser and/or a normal gamut monitor, it's tagged in ProPhoto RGB.
Taking a CMYK color reading, from right between her eyebrows, the Magenta value is slightly higher than the Yellow.
Chas P
Redcrown
Jan 20, 2011 13:09 |  #7
Looks OK to me, but you will get different opinions, simply because of different personal tastes and differences in human perception. Not to mention differences in monitors, even "calibrated" monitors.
Best way to cut through those differences in to look at the numbers. A while back I wrote about a technique to analyze the numbers in skin tones, and posted it here:
http://forums.dpreview​.com …rum=1006&messag​e=37129263 (external link)
Here is a sample of that technique used on your image. It is a "mask" showing the balance of magenta and yellow, which are the key elements of skin tone. In the left image, lighter tones show where yellow exceeds magenta. In the right image, lighter tones show where magenta exceeds yellow. Don't pay any attention to hair, eyes, lips. Just look at the skin areas.
http://kellyphoto.smug​mug.com/photos/1162723​804_87Cdn-O.jpg (external link)
IMAGE: http://kellyphoto.smugmug.com/photos/1162723804_87Cdn-O.jpg
Overall, this analysis says you image is in good shape. Magenta exceeds yellow on the cheeks, chin, and nose. That means they look a little "pink", which is normal. Yellow exceeds magenta only down the right side of her face. But well within a "normal" range. On the majority of her face, yellow and magenta are equal. Common guidelines call for yellow and magenta to be equal, with yellow slightly greater. Common guidelines say magenta should never exceed yellow.
But then personal taste enters the equation. Some people like "rosey red cheeks" where magenta would exceed yellow. Some women apply "rouge" makeup to get that effect. Some people think "tan" skin looks healthier, with yellow greater than magenta by 10% to 25%.
tonylong
...winded
Gallery: 60 photos
Jan 20, 2011 16:33 |  #8
I will say (adding to Chas's comment) that it makes a big difference if you are looking at it in a color-managed app -- looking at it in my non-color managed IE makes it look way coolish. in other words, uploading this in the ProPhotoRGB will throw a lot of people off in viewing it. Converting it to sRGB will make it more universally viewable.
Tony
Peano
Jan 20, 2011 17:18 as a reply to  @ tonylong's post |  #9
Yes, stick to sRGB for the web.
IMAGE: http://img267.imageshack.us/img267/8229/kristinacompare.jpg
In sRGB, skin tones need only a tweak.
IMAGE: http://img585.imageshack.us/img585/6476/kristinaadjust.jpg
Peano
RadiantPics.com (external link)
x0SiN0x
Jan 20, 2011 17:52 |  #10
Thanks all! This was quite a learning experience
tonylong
...winded
Gallery: 60 photos
Jan 20, 2011 17:55 |  #11
Peano, exactly! And, in DPP I did a very simple pulling down on the Red curve to get a very similar look to yours (and just a bit on the Blue). The reds are indeed a bit over the top on the original.
Tony
jase1125
Jan 20, 2011 20:55 |  #12
Redcrown wrote in post #11679599 (external link)
I was looking at your post on dpreview....did you happen to create an action for those steps?
Jason
Redcrown
Jan 20, 2011 23:18 |  #13
I've got an action for my own use. But it's not "polished" for publication, and has no documentation. But if you want to try it, here's a download.
http://www.mediafire.c​om/?7a3b2all4fg26c8 (external link)
Basics:
Run it with only one document open.
It creates a layer group in your document with pre-built Curves to reduce Magenta and Yellow. The masks are in the Curves layers. Both Curves are turned off by default. Turn one or both on. Usually you need only one.
Paint black on the Group layer mask to hide areas outside of the skin you want to adjust. Adjust the opacity of the Group or Curves layer to taste.
The action creates a dupe of your doc, converts the dupe to CMYK mode, creates the masks there, and copies them back to your original. Then it deletes the temp CMYK doc. Because is uses a temp dupe, the action won't work correctly if you have multiple docs open. So run it with only your main doc open.
jase1125
Jan 21, 2011 15:55 |  #14
Thanks for sharing!
Jason
3,966 views & 0 likes for this thread, 9 members have posted to it.
1452 guests, 137 members online
