dp19 wrote in post #11680601
The question I wanted to ask is - What lens do I need?
If you can get close to an airplane, as happens with the ramp and static displays at an air show, you'll need a wide-angle lens, such as the Canon 18-55mm image stabilizer lens.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
Focal Length: 18.0mm
Aperture: f/10.0
Exposure Time: 0.0040 s (1/250)
ISO equiv: 100
Exposure Bias: none
Metering Mode: Matrix
Exposure: program (Auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
If the airplane is in the air, then you'll want the longest lens you can afford or carry. 400mm is a good starting point.
Focal Length: 400.0mm
Aperture: f/18.0
Exposure Time: 0.0050 s (1/200)
ISO equiv: 200
Exposure Bias: none
Exposure: shutter priority (semi-auto)
White Balance: Auto
Orientation: Normal
Color Space: sRGB
This air show image came from a Tokina 80-400mm lens. Others will want to start with a Canon 100-400mm lens. Longer lenses may be more useful, but they will certainly be very expensive.
