josullivan79 wrote in post #11686352
I'm still learning/trying to figure out color spaces myself. what's the benefit of using aRGB? for print?
There are scenes where you may have bright/saturated colors that push outside of sRGB but can be managed in aRGB -- think bright flowers or bright saturated fabrics. In those conditions, you may do better both using the aRGB color space in the camera with the RGB histogram to fully capture things and retain those colors in your jpeg without underexposing and in your processor to have manage things in your Raw file and finally to be able to print to a printer that actually handles the aRGB gamut properly.
Now, that sounds nice, but there are problems there that can bite you if you don't know what exactly you are doing in post processing images like this. For example, when you shoot Raw+jpeg you have "locked in" that color space with the brighter colors in a way that may be problematic if, say, you need to convert them to the sRGB color space for the Web or for others to view in a non-color managed application.
Also, consumer monitors tend to have a more narrow color space so that even with your Raw files what you see on the screen will likely not be accurate with one of these aRGB images if in fact it contains colors that are out of the sRGB gamut.
You can use tools to work with these images -- the color histograms in your software, for example, and, if you have Photoshop using the Soft Proof function with out-of-gamut warnings will help you to manage things. You will need to consider both printing issues and also the fact that when you want to convert an image for the Web you will want to convert it to the sRGB color space and that could mean doing some tweaking to the color channels to bring them into line.
So, especially when you shoot Raw+jpeg, setting your camera to sRGB can be considered "safe" -- your histogram in the camera will reflect that meaning that using the RGB histogram will enable you to keep your exposure for bright/saturated colors in line and your jpeg will be Web-ready.
As you go, you may want to experiment, especially using the Raw files and various techniques there to squeeze more out of your image and out of a print, but then realize that your jpegs don't have as much latitude there and will bang up against limits earlier. And, such experimentation means that you will be pushing against limits even with Raw files.
