It says it's compatible with a 5D, but there's no mention of 5D Mark II so I'm unsure if i should pull the trigger.
http://www.amazon.com …ics&qid=1295632745&sr=1-1![]()
Thanks!
pixelmorph Member 100 posts Joined Dec 2010 Location: Playa Del Rey More info | Jan 21, 2011 12:04 | #1 It says it's compatible with a 5D, but there's no mention of 5D Mark II so I'm unsure if i should pull the trigger.
Jan 21, 2011 12:05 | #2 Oh btw, my purpose for these is only to use as a wireless remote release which will in turn trigger my radiopoppers... hopefully
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Jan 21, 2011 12:20 | #3 I think all they are trying to imply is that you get the camera trigger cord for that series of camera. All it is doing is shorting a couple of contacts to focus and then release the shutter so if you buy the one with the correct cord you should be okay. There is no difference between the remote cord for the 5d and the 5dII.
Jan 21, 2011 12:23 | #4 pixelmorph wrote in post #11686074 It says it's compatible with a 5D, but there's no mention of 5D Mark II so I'm unsure if i should pull the trigger. http://www.amazon.com …ics&qid=1295632745&sr=1-1 Thanks! I have the same from amazon and it works flawlessly on Canon 5D MKII. Even the remote shutter release works well.
Jan 21, 2011 12:29 | #5 [There is no difference between the remote cord for the 5d and the 5dII.]
Jan 21, 2011 12:30 | #6 Ahh... i just now discovered the quote button. Sorry guys, I'm new!
Jan 21, 2011 12:48 | #7 pixelmorph wrote in post #11686236 [There is no difference between the remote cord for the 5d and the 5dII.] Great, because that's what I was worried about. [I have the same from amazon and it works flawlessly on Canon 5D MKII. Even the remote shutter release works well.] Perfect! Have you tried using it in continuous or bulb mode, btw? Nope I haven't tried it in continous mode. I guess it should work if it triggers shutter.
Jan 21, 2011 12:55 | #8 Thanks alot guys!
JohnSchell Senior Member More info | Jan 21, 2011 13:21 | #9 |
| Latest registered member is Mihai Bucur 1450 guests, 114 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
