Anyone do this at receptions? I was wondering if you find that there's typically enough light to focus and then just being able to hold the 580exii to get desired angles
SamHunter Senior Member 960 posts Likes: 2 Joined Apr 2008 Location: Louisville, KY More info | Jan 21, 2011 12:07 | #1 Anyone do this at receptions? I was wondering if you find that there's typically enough light to focus and then just being able to hold the 580exii to get desired angles Louisville, Kentucky Wedding and Portrait Photography
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 21, 2011 16:49 | #3 How I photograph wedding receptions. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
RedTiePhotography Goldmember 3,575 posts Likes: 1 Joined Nov 2009 Location: San Diego More info | Jan 21, 2011 19:03 | #4 SamHunter wrote in post #11686100 Anyone do this at receptions? I was wondering if you find that there's typically enough light to focus and then just being able to hold the 580exii to get desired angles I find there is not normally nearly enough light to focus, so the flash on camera is almost always mandatory (for me). I dont want the annoying pop up flash machine gun to try to focus. Bryan
SamHunter THREAD STARTER Senior Member 960 posts Likes: 2 Joined Apr 2008 Location: Louisville, KY More info | Jan 22, 2011 12:05 | #5 Red Tie Photography wrote in post #11688436 I find there is not normally nearly enough light to focus, so the flash on camera is almost always mandatory (for me). I dont want the annoying pop up flash machine gun to try to focus. Also, with radio triggering being so cheap, no idea why you wouldnt try that out. Check out the Cactus V4 for a cheap alternative. I have Cybersyncs, I was just curious about this because of ETTL Louisville, Kentucky Wedding and Portrait Photography
RedTiePhotography Goldmember 3,575 posts Likes: 1 Joined Nov 2009 Location: San Diego More info | Jan 22, 2011 13:36 | #6 I think it would be fine if you are doing some hobby shots, or in a more controlled environment, but I wouldnt use it for a wedding. Bryan
CTP Senior Member 353 posts Likes: 3 Joined Feb 2010 Location: Northern Illinois More info | Jan 22, 2011 13:38 | #7 Red Tie Photography wrote in post #11692732 I think it would be fine if you are doing some hobby shots, or in a more controlled environment, but I wouldnt use it for a wedding. Dead on, I tried it with my 7D and I will never use it again in a Wedding/Reception environment. Radio is the way to go. EOS R + 5D4, 16-35L II, 24L TS-E II, 24L II, 50L, 85L II, 100L, 135L, 70-200L 2.8 IS II, RF 28-70L, 580ex IIx2
viet Goldmember 1,019 posts Joined Jul 2007 More info | Jan 23, 2011 18:50 | #8 Pop up is simply too weak for making wireless trigger at weddings. Use external trigger like PW or popper, you'll retain ettl with the latest models.
Furner Member 121 posts Joined Jun 2007 More info | Jan 24, 2011 11:56 | #9 viet wrote in post #11700497 Pop up is simply too weak for making wireless trigger at weddings. Use external trigger like PW or popper, you'll retain ettl with the latest models. Not to mention you will not be the only camera flash in the room, burning your batteries, or putting your flash into recharge .1 secs before you hit the trigger. Canon 30D, 40D, 17-55mm f/2.8, 50mm f/1.8, 430EX, strobist stuff.https://photography-on-the.net/forum/showthread.php?t=888751
Dr.Pete Senior Member 984 posts Joined Jan 2010 More info | Jan 24, 2011 13:01 | #10 Not that the answer is any different, but the 7D has a built-in speedlite transmitter that doesn't rely on the firing of the built-in flash, i.e. it's not an optical slave setup. That being said, I don't think it's a viable option for carrying a flash in hand, because the 580EXII will be outside the transmitter's "cone" and might not get triggered. Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Jan 24, 2011 13:08 | #11 Dr.Pete wrote in post #11705164 Not that the answer is any different, but the 7D has a built-in speedlite transmitter that doesn't rely on the firing of the built-in flash, i.e. it's not an optical slave setup. The 7D (and now the 60D) does use the built-in flash to optically trigger off-camera speedlights via ETTL. You can set it up so the built-in flash doesn't contribute to the exposure, but it MUST be "popped up" to trigger your off-camera lights.
RedTiePhotography Goldmember 3,575 posts Likes: 1 Joined Nov 2009 Location: San Diego More info | Jan 24, 2011 13:26 | #12 egordon99 wrote in post #11705218 The 7D (and now the 60D) does use the built-in flash to optically trigger off-camera speedlights via ETTL. You can set it up so the built-in flash doesn't contribute to the exposure, but it MUST be "popped up" to trigger your off-camera lights. Nikon and Pentax have had this capability for quite a few years before the 7D came out. True, but other people's p&s camera flash is not going to set off the 580. Bryan
Dr.Pete Senior Member 984 posts Joined Jan 2010 More info | Jan 24, 2011 13:26 | #13 egordon99 wrote in post #11705218 The 7D (and now the 60D) does use the built-in flash to optically trigger off-camera speedlights via ETTL. You can set it up so the built-in flash doesn't contribute to the exposure, but it MUST be "popped up" to trigger your off-camera lights. Nikon and Pentax have had this capability for quite a few years before the 7D came out. That doesn't make any sense. If it's just an optical trigger, then any camera with a flash has that "feature." The slaves do not fire in response to the visible light coming from the 7D, and IIRC you can completely disable the 7D's built-in flash but it does need to be up in order to use the transmitter function. The device is similar to the ST-E2, which also emits no visible light. Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
bigarchi Senior Member 962 posts Likes: 1 Joined Mar 2008 Location: upstate ny More info | Jan 24, 2011 15:59 | #14 Dr.Pete wrote in post #11705353 That doesn't make any sense. If it's just an optical trigger, then any camera with a flash has that "feature." The slaves do not fire in response to the visible light coming from the 7D, and IIRC you can completely disable the 7D's built-in flash but it does need to be up in order to use the transmitter function. The device is similar to the ST-E2, which also emits no visible light. its not "just an optical trigger" ~Mitch
tolyD Senior Member 723 posts Joined Apr 2010 Location: Minneapolis More info | Jan 24, 2011 16:18 | #15 You mean coctus v4? bigarchi wrote in post #11706258 its not "just an optical trigger" canon's speedlights wouldn't respond to it if was, let alone be able to communicate in ettl. The 7D uses IR, but simultaneously flashes to communicate with the flash. So there is visible light as well as IR coming from the 7D's little flash, unlike the st-e2, which as you noted emits no visible light. i like the ability to use it while messing around at home, and i have used it with success doing product shoots on location. but i would not rely on it at all in an event, as others have mentioned. i do rely on the IR from a 580 when triggering other speedlights when i'm doing formals at the altar or something though. always seems to work well and consistent enough. unlike my v4s that ONLY work when no one else is looking ![]() 5D MkII | 35L | 50 1.4 | 85 1.8 | 2x 580ex II |
| Latest registered member is Niagara Wedding Photographer 1340 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
