Thread started 21 Jan 2011 (Friday) 14:39
60D or 7D
DanThoman
Jan 21, 2011 14:39 |  #1
I'm thinking about a new camera body was wondering what people thought about the 60D and the 7D. I can't see much difference in the specs except for the fps but there is a huge difference in the price. Is the 7D worth the extra money?
Dan
my gear
Zebodog
Jan 21, 2011 14:43 |  #2
DanThoman wrote in post #11686974 (external link)
If you shoot a lot of sports or fast action then it probably would be. The AF system on the 7d is far superior to the 60d.
tohara
Jan 21, 2011 14:45 |  #3
you need to do more research. Completely different cameras.
Unless you need video there wouldn't be much reason to go from 50d to 60d in any hurry
500px (external link)
Sony A7r | Leica M6 Titanium | Ricoh GR1 | Nikon FM2 | Pink Lomo Sprocket Rocket
Zeiss 55mm f1.8 | Leica 35mm f2 Summicron ASPH | Polaroid Cool Cams (external link)
Zebodog
Jan 21, 2011 14:49 |  #4
tohara wrote in post #11687002 (external link)
To say they are completely different cameras may be a slight exaggeration; after all the sensor is the same. I would agree however that they are targetted at completely different markets.
Steve ­ Beck
Jan 21, 2011 14:53 |  #5
Many threads about this same question.
https://photography-on-the.net …rch.php?searchi​d=24176882
Gear List? My gear is bigger than yours? Just shoot have fun...
shoturtle
Jan 21, 2011 14:53 |  #6
If you shoot allot of action, the 7d is the better option and is worth it. As it has the better AF system and faster fps rate.
Here is a podcast with canon rep Rudy Winston. I went to one, and it help me decide which camera fits my shooting best. There are 3 podcast. It is a bit of time to go through all 3.
http://www.video.bhpho​tovideo.com …dbee4f4d48db9a2​6a992d3ab2 (external link)
Traveling is my passion, so I am a major Frequent Flyer.
Canon 60D, T1i/500D, Eos 1, Eos 630, and Olympus epl-1. Current Canon Lenses ef 100 2.8, ef 85 1.8, ef 50 1.4, ef 28 1.8, ef 50 1.8,ef 28-135, ef 70-300, ef-s 18-55, ef-s 55-250, 500D close up lens. Current Olympus lenses oly m4/3 14-42, oly 4/3 35mm 3.5 macro with m4/3 adapter, panasonic 45-200, panasonic 20 1.7. And a Part time Pentax K-X shooter.
MGiddings ­ Photography
Jan 21, 2011 14:53 |  #7
Best go and hold them both and see which feels the most comfortable in your hands. I suspect to &d will be more your thing having already owned a 50D.
https://mgiddings.com (external link)
AlanU
Gallery: 144 photos
Jan 21, 2011 14:56 |  #8
If MA means anything to you the 7D is the only choice.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
DanThoman
Jan 21, 2011 14:59 |  #9
I'm not interested in video at all. My research has shown the AF to be only slightly better. What I like about the 60D is the articulated screen (for macros) which the 7D doesn't have. Both have wireless flash control which is a definite plus for me.
Dan
my gear
LiberationFrequency
Joined Jun 2010
Jan 21, 2011 15:00 |  #10
Video only - 60D
Stills - Split
Fast Pace shooting - 7D
Depends on the ratio and what you are shooting. Not saying the 7D is bad for video, but you can't turn off AGC and you can't run magic lantern.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 21, 2011 15:00 |  #11
7D over the 60D:
- higher fps
- larger burst buffer size
- 19 af points
- more AF modes, better control of certain macro lenses
- better AF, akin to 1D series vs the 50D AF on the 60D
- focus microadjustment
- larger beefier body
- better weather sealing
- less drama and bashing on the forums
- dual processors, dedicated AF controller
- better viewfinder
- electronic focus screen w/electronic level, grid lines
- EDIT: forgot the magnesium body, not something that crosses my mind when I use it
From memory anyways, I am probably missing a couple of things...
My 7D is on its way to a new owner this afternoon, I think I will miss it (for a while anyways).... :(
KaBlookie
Joined Sep 2009
Jan 21, 2011 15:01 |  #12
*edit* holy cow, I guess I took too long to write this...wrote it when there were two replies :P
I went through this debate a couple of weeks ago and ended up getting a used 7D. Now, especially after playing more with my friend's 60D, I'm glad I forked over the extra little bit for the 7D.
The 7D does have a faster constant-fire, but there's more:
- dual processors for faster image processing (also allowing more FPS)
- I believe constant-fire buffer is larger or doesn't fill up as quickly due to faster processors? (someone correct me if I'm wrong here)
- CF memory cards vs SD (I think that's a plus...fast SD cards are INSANELY expensive)
- has the same joystick your 50D has
- many more focus points and focus point modes
- more advanced focusing system
- you can display a grid in the viewfinder
- no swivel screen, so one less thing to worry about (although some people like it, and others say it's very strongly built)
- magnesium body vs plastic (although the 60D is still a SOLID camera)
- slightly bigger and heavier overall, especially in the grip, good for if you like that or if you have bigger hands
There's definitely more but you should definitely just go to a store and play with both for a good bit to really see the differences and FEEL for yourself how they operate.
7D - XTi - Tamron 17-50mm f/2.8 - Canon 50mm f/1.8II - SMC Takumar 50mm f/1.4 - Canon 70-200mm f/2.8L - Lensbaby 2.0 - Canon 430EX-II - CBS flash trigger
Darkwand
Jan 21, 2011 15:06 |  #13
7D has better grip :)
Adrian My Flickr (external link)
Canon 5D MkIV, Canon 6D, Canon 7D, Canon 18-55mm 3.5-5.6 IS, 17-55mm f/2.8 IS USM, 50mm f/1.4 USM, 85mm f/1,8 USM, Sigma 70-200mm HSM Macro, 10-20mm f/4-5,6
Manfrotto 055 CXPRO4 + 498RC2, Manfrotto 410 Junior, Elinchrom: RX1200, 2x BRX250 , Dlite-it 4 and 2, Canon 580EXII
Tommydigi
Gallery: 66 photos
Jan 21, 2011 15:10 |  #14
Not sure if cost is an issue but I got a 60D with a free slingshot bag from Newegg for 900.
Website (external link) | Flickr (external link) | Instagram (external link)
Fuji X100F • Canon EOS R6 Mark 2 • G7XII • RF 16 2.8 • RF 14-35 F4 L • RF 35 1.8 • RF 800 F11 • EF 24LII L • EF 50 L • EF 100 L • EF 135 L • EF 100-400 L II • 600EX II RT • 270 EX II
NeverFollow
Joined Jun 2005
Jan 21, 2011 15:11 |  #15
I had the same dilemma a couple of months ago. I wanted a camera that I would be completely happy with for the next couple of years, so I went with the 7D and I couldnt be happier.
https://500px.com/chri​skennedydotphoto (external link)
2,665 views & 0 likes for this thread, 14 members have posted to it.
60D or 7D
926 guests, 115 members online
