Thread started 22 Jan 2011 (Saturday) 08:05
Tamron SP AF 17-50mm F2.8 XR Di II VC experience
mghong
Jan 22, 2011 08:05 |  #1
Hi ,
Just want to share my experience on this lense.
Yesterday bring in my new bought 17-50 vc to a test ,2 thing i notice it when pair with my 350D
1) Focus not working , i saw that a red cross in viewfinder but when i pull the trigger(snap) it just did't work , even AF is not working too.
2)Error display on my panel and i try to off and on still can't help
the only workaround is to replace another lense and put it back again then it work fine
Problem is i can't reproduct the problem...how can i approach service center ?
Just another fan of Canon
http://jessiray.co.cc (external link):)
Gadget - Canon 350D,50mm 1.8 ,18-55mm kits lense , Tamron 17-50 F2.8 VC
watt100
Jan 22, 2011 08:09 |  #2
mghong wrote in post #11691175 (external link)
Hi ,
so the mysterious problem only occurs in your the house?
I see, you put another lens on then take it off and put the Tamron lens back on and then it works fine?
mghong
Jan 22, 2011 08:20 |  #3
yes , i try my 50mm and it work fine till i decide to give that 17-50 another try again..
mrrikki
Joined Nov 2010
Jan 22, 2011 09:29 |  #4
Take it back to the store you got it from?
GEAR: Canon 7D Mark II, 7D & 6D Lenses: Canon 300 f2.8 L IS, 70-200 f2.8 L, 24-105 L, Canon 50mm f1.8 & Sigma 1.4x Converter.
Website www.rmtphotos.co.uk (external link)
muskyhunter
Joined Nov 2010
Jan 22, 2011 12:18 |  #5
get another lens.
watt100
Jan 22, 2011 14:19 |  #6
muskyhunter wrote in post #11692369 (external link)
get another lens.
the OP hasn't come back so maybe all is well now
mghong
Jan 23, 2011 09:26 |  #7
too bad , i going for a trip for 2molo will only back on friday ,will confirm to bring the lense back to the shop and claim for a new set...:(
mghong
Feb 05, 2011 11:42 |  #8
back from my trip , and it happen 2 day on 2 different day..
this time i notice there is error code on the LCD "Error 01" now i need to arrange to spent time to meet with the shopper to send for warranty
thatkatmat
Gallery: 41 photos
Feb 05, 2011 14:32 |  #9
Pretty sure thats the lens not communicating with the camera, use an eraser (like on the end of a pencil) and clean the contacts on both the lens and the body....Should fix it, if not....and it doesn't ever happen with any other lens than the Tamron...then send the lens in....But the eraser deal should work..
Cheers
My Flickr (external link)
Stuff
LightRules
Return of the Jedi
Joined Jun 2005
Feb 05, 2011 14:35 as a reply to  @ thatkatmat's post |  #10
I've used 3 copies of the VC on 2 bodies and never a problem.
Try what Matt said with the eraser to the contacts. Otherwise, it'll need a service trip. Fine lens though.
Silverfox1
Feb 05, 2011 15:25 as a reply to  @ LightRules's post |  #11
This was a reported problem with Nikon users of this lens and also several folks here on POTN had this communication error problem also on their Canon bodys. This occurred when Tamron initially released the VC version on the market which obviously was due to 1st batch QC production run issues.
Cleaning the contacts did not rectify the issue.
Of course Tamron never publicly admitted it with a revision but the vendors were getting alot of initial release returns.
The OP could have possibly received a 1st production run copy from the seller or a returned copy that was never sent back to Tamron by the vendor.
The OP might check with some of the Canon owners here in the Lens archive section and ask about their serial numbers numeric value and compare them to his.
Check out this early lens copy release : https://photography-on-the.net …hp?p=9161584&po​stcount=36
Regards, ;)
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
3,855 views & 0 likes for this thread, 7 members have posted to it.
1698 guests, 167 members online
