Thread started 22 Jan 2011 (Saturday) 18:15
PS Gurus - any way to watch the color ajustments real time?
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jan 22, 2011 18:15 |  #1
In PS CS3, I am wanting to watch color adjustments real time.
Specifically, this: When I use the a point selection (eyedropper) tool, and look under the INFO tab, I see the 0-255 values for each of the RGB components of the color I have selected.
Is there any way to keep that area displayed - with real time numerical updates - as I make global adjustments to the hue, saturation, white balance etc, etc of the entire image?
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
chrisa
Gallery: 188 photos
Jan 22, 2011 18:43 |  #2
Shift click with the eye dropper tool up to 4 times.
Peano
Jan 22, 2011 20:00 |  #3
chrisa wrote in post #11694480 (external link)
Rad: When you shift-click with the eye dropper, it sets sample points that you can read on
the Info panel. You can set up to four sample points on an image. When you make changes
with adjustment layers (curves, color balance, selective color, etc.), you can see the
changes, real-time, on the sample points.
IMAGE: http://img696.imageshack.us/img696/8696/samplesy.jpg
Peano
RadiantPics.com (external link)
Radtech1
Joined Jun 2003
Jan 22, 2011 22:08 |  #4
VERY awesome.
Restoring a photo that has had a paper mat around the subject since 1967. Sever color shift in the area that was not matted. Now I can sample an area of the b.g. on the previously shielded area and use that as a target to color correct the rest of it.
Thanks!
agedbriar
Jan 23, 2011 07:58 |  #5
Outside Photoshop, Colour Watcher may do the job:
http://www.broadhurst-family.co.uk …inpages/colourw​atcher.htm (external link)
ChasP505
"brain damaged old guy"
Jan 23, 2011 11:29 as a reply to  @ agedbriar's post |  #6
Rad, of course you can also switch from RGB to CMYK, which some find more useful.
Chas P
1,409 views & 0 likes for this thread, 5 members have posted to it.
1048 guests, 105 members online
