Thread started 22 Jan 2011 (Saturday) 21:20
Inexpensive seven-inch monitor that's compatible with Canons
MikeFairbanks
Jan 22, 2011 21:20 |  #1
Check this out: http://www.amazon.com …/ref=cm_cr_pr_p​roduct_top (external link)
I saw it at Best Buy (for 69 bucks), opened the box, and it comes with the connectors that will hook up to your camera (using your camera's cables as well). Looks like there's nothing additional to buy.
I haven't purchased and tried it yet, but I think it might just work for an inexpensive additional monitor that might help to focus better and frame (since the 7D, T2i and T1i don't have articulating screens).
Might even be good for 60D users since it's seven inches.
According to the reviews, one of the drawbacks is the short battery life. Most are saying they only get about and hour and a half with it. You could plug it in (if you are shooting in a stationary situation), but on the go it just might work.
What do you think?
Thank you. bw!
Channel ­ One
Joined Nov 2010
Jan 23, 2011 05:37 |  #2
MikeFairbanks wrote in post #11695247 (external link)
What do you think?
At that price break overlooking the power problems it could work as a very basic field monitor though I would prefer one that utilizes replaceable batteries.
Wayne
Do what you love and you will love what you do, that applies to both work and life.
SDSupra
Jan 23, 2011 05:41 |  #3
Looking at the pics on bestbuys site it doesnt look like it will be compatible with our 7D's. It comes with a mini jack to analog female rca for AV input. Our AV OUT is digital with mini USB I believe...
On another note... Sony is releasing a nice 5" clip on LCD monitor designed specifically for DSLR's. Comes out in March, couple of months, with no announced price.
Canon 7D Gripped | EF 50mm f/1.4 USM | EF-S 18-135mm IS | Speedlite 430EX II
iMac 27" I5
flickr - JPMEDIA (external link)
Channel ­ One
Joined Nov 2010
Jan 23, 2011 05:54 |  #4
SDSupra wrote in post #11696730 (external link)
While I have never connected a field monitor to the 7D I thought one could connect the Canon supplied analog A/V cable to the USB port and export analog video to a monitor, though in this case it would require using RCA to RCA connectors to adapt the canon A/V cable to the supplied monitors A/V cable.
Now the output is not going to be HD as that would require using a HDMI cable from the 7D to a compatible monitor.
Wayne
peter ­ nap
Jan 23, 2011 06:04 |  #5
Channel One wrote in post #11696764 (external link)
Wayne
You are correct about that Channel One.
MikeFairbanks
Jan 23, 2011 09:04 |  #6
No, no. Guys, I checked. The RCA connectors that leave the DSLR's mini USB port are male. The RCA cables that come with the little TV are female, and then merge to plug into the 1/8 inch port on the side of the TV (and the port is labeled AV in). I think it will work.
I'll probably pick it up and try.
My main reason is focus and framing, not quality.
When I'm ready to shoot a scene I'll do a test first (using the lcd screen on the camera), get the settings I like, and then use the external monitor for framing and focus (since you can see detail better for focus---I hope).
The real question becomes: Will a seven-inch screen with lower quality and lower resolution give a better view of focus than a higher-quality 3-inch lcd screen on the camera.
Thank you. bw!
peter ­ nap
Jan 23, 2011 09:24 |  #7
MikeFairbanks wrote in post #11697343 (external link)
It will work Mike!
I have the same setup with a 7" Auvio TV I use sometimes.
The next question is the killer. It really won't help with focus. It's just not sharp enough.
It is great for framing and just to monitor, just not for focus work.
It's at it's best when the 7D is on a pole or somewhere else I can't get to and I don't want to hook a laptop up.
I also use it with some of the Smaller video cameras including my GoPro.
In all honesty, I bought it because I needed video of someone who did not want to be videoed by me, and was giving an interview in a TV station. I set it up so I could watch the interview then switch to monitor the camera on a tripod, then start recording with a wireless remote, as he walked out.
Otherwise, I'd never have a low res field monitor.
Chippy569
Jan 23, 2011 10:07 |  #8
Here's some others you might want to consider: http://www.cinema5d.co​m/news/?p=2262 (external link)
* smallHD DP-1
* ikan V8000HDMI
* Marshall V-LCD70P-HDMI
* ikan V5600
SmallHD (external link) is $900
ikan V8000 (external link) is also $900 (also 8")
ikan V5600 (external link) is $600, at 5.6"
The marshall in the review I believe has been replaced, but their V-LCD50-HDMI (external link) (5.6") is $600
IMO the "false color" in the marshall is a great way to check exposure.
David Nichols (external link) - Sound Designer
How to export to Youtube HD from Quicktime
SketchyUnicorns
Gallery: 21 photos
Jan 23, 2011 11:25 |  #9
^^ Talk about highly priced. I can make mine a touch screen if i wanted for that price.
The power problem is a very very easy fix as well as if you wanted to make it replaceable or just to last longer.
I have a 7" screen as well but you have to plug it in. I have had it for many years now and it was originally used to play xbox games on traveling (lol) but now i use it for my camera. I am working on putting a remote in it so itll be a screen as well as a remote that can change the aperture, shutter, iso, and some normal remote stuff. Its not difficult to do the batter but remote part is an annoying part as you have to do slight programing.
Just my $0.02
Canon 7D Mk2, Sony A7iii, Canon 85mm f1.8, Canon 70-200mm f2.8 IS mk1, Sigma 17-55mm f2.8, Tamron 28-75iii, a few flashes and many modifiers
SmugMug (external link)
flea
Jan 23, 2011 11:30 as a reply to  @ SketchyUnicorns's post |  #10
Look on amazon for the haier 7", I believe it's $50 and works great. Otherwise the axion that I seen at best buy had a coaxial input. There was another brand that I got from best buy last week that had minijack av input, but I forgot the brand.... I'll check it later tonight, but it works great!!!
EDIT:::
The Brand was Eviant. Model was T7DC and i got it for 74.99. great deal!!! definitely helps me with my focusing
[SIZE=1]5DmkII GRIPPED /-/ 17-40 f4L /-/ 70-200 f4L[B] /-/ 50 f1.8 /-/ 100 f2.8 /-/ 15 fisheye /-/ 580exII /-/ 2x extender
MikeFairbanks
Jan 23, 2011 12:47 |  #11
Something else to consider (and this has more to do with photography than video) is elevated photography.
There's a relatively new field of photography called PAP (pole aerial photography) that works great for real estate, particularly properties on the water and more.
You see, the whole idea is to elevate your camera (usually to about 30 feet is the average) to get a great shot that includes not only the front of the house (all real estate shots do that), but the back of the house as well. If there's a lake back there or a beatiful pool, yard, beach, etc., then the potential customer sees a much better angle than the typical street view.
I have friends who do it for extra money and do quite well with it. I don't know anybody doing it full-time, but I'm sure some people do.
Here's a pic and a link of a business that does this(I know the owner and he doesn't mind). Southernballoonworks.c​om
IMAGE: http://www.aerialproducts.com/images/aerial/pneumatic.jpg
Thank you. bw!
Bobabooey24
Jan 23, 2011 13:20 |  #12
I have the lilliput 7" and its great!
SDSupra
Jan 23, 2011 13:38 |  #13
Wayne
I stand corrected sir! You're right. I didnt know what you guys were talking about with the connector so I looked in my original 7D box and there was the mini USB to male rca connector! lol Apparently I never took it out of the box, I always use HDMI.
I may be picking this up then, I have $70 of bestbuy giftcards and reward points I havent used yet...
iMac 27" I5
MikeFairbanks
Jan 23, 2011 13:47 |  #14
My concern has mostly been focusing issues. I find it hard to focus using that small three-inch screen on the T2i. It's a fantastic screen, but it sure is small for shooting video (if using a shallow depth of field.
Stopping down to about 11 helps a lot, but once you get that image onto a big screen tv you can see the focusing mistakes really easily.
SO, those expensive monitors (that usually start at about 500 or more) are for tackling this issue.
It sounds (and someone else mentioned it) that the cheap one from Best Buy will only be practical for framing the subject.
That's great, however. And with the proper homemade rig will be able to articulate.
Thank you. bw!
Chippy569
Jan 23, 2011 14:05 |  #15
Bobabooey24 wrote in post #11698607 (external link)
interesting, might not be bad: https://www.eio.com …vgahdmi-or-dvi-input.aspx (external link)
4,876 views & 0 likes for this thread, 14 members have posted to it.
1012 guests, 110 members online
