A lot of glamor and wedding photography I've been checking out seems to be shot at ISO 400 with flash. Why? Wouldn't ISO 100 be better?
antifire Senior Member 667 posts Joined Oct 2010 Location: Munich, Germany More info | Jan 23, 2011 13:16 | #1 A lot of glamor and wedding photography I've been checking out seems to be shot at ISO 400 with flash. Why? Wouldn't ISO 100 be better?
Jan 23, 2011 13:33 | #2 In Manual mode if ISO is left on auto then it will be fixed at ISO 400. My guess is that a large portion of photographers leave their camera on auto ISO. Please visit my Flickr
pophoto Senior Member 580 posts Joined Aug 2009 More info | Jan 23, 2011 13:55 | #3 A high ISO will provide you with a more ambient looking background. A lower ISO will show the background on the darker side. I use my ISO to create a desired looking ambient light setting. Canon 5D Mark II - 24-105mm, 100mm macro, 70-200mm 2.8L
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jan 23, 2011 14:41 | #4 The quality of ISO400 now is very similar to ISO100 digital...so why not?! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Jan 23, 2011 15:16 | #5 thanks for the input!
tonylong ...winded More info | Jan 23, 2011 16:07 | #6 pophoto wrote in post #11698837 A high ISO will provide you with a more ambient looking background. A lower ISO will show the background on the darker side. I use my ISO to create a desired looking ambient light setting. I have experimented with a standard setting of lets say 1/80 and 5.6 (in manual with a flash) ... and vary the ISO from 125 to 800. I then internalize the effect that the ISO has on the ambient lighting. I generally use 400 to 800 ISO> Although I'm not a wedding photog, I'll agree with this statement -- I don't approach shooting people indoors as if it is a studio with all controlled even lighting, but more for a ambient look where the flash contributes enough light to fully illuminate and freeze motion but having a reasonably slow shutter speed with a higher ISO lets the ambient light give some "atmosphere". Tony
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 23, 2011 18:20 | #7 ISO 400 requires less flash power, and image quality is much the same as ISO100. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
TooManyShots Cream of the Crop 10,203 posts Likes: 532 Joined Jan 2008 Location: NYC More info | Jan 23, 2011 19:18 | #8 Permanent banAs another has pointed out, is about the ambient light. I know you may not understand it but when the ISO is high enough, 400 or higher, you can allow more ambient light to fill in the frame. Why it is important? You want a good balance between the flash and ambient lights to give an even light look. The will result in either you can or can't see the background because of the ambient light there or not there. One Imaging Photography
BeachcomberJoe Senior Member 466 posts Likes: 3 Joined Jan 2010 Location: Southwest Florida More info | Jan 23, 2011 19:59 | #9 Sdiver2489 wrote in post #11698694 In Manual mode if ISO is left on auto then it will be fixed at ISO 400. That is true on my T1i. My 7D, on the other hand, varies the ISO up to 3200 depending on the shooting condition.
tonylong ...winded More info | Jan 23, 2011 22:43 | #10 Beachcomber Joe wrote in post #11700881 That is true on my T1i. My 7D, on the other hand, varies the ISO up to 3200 depending on the shooting condition. Even when shooting flash? Tony
kjonnnn Goldmember 1,216 posts Likes: 148 Joined Apr 2005 Location: Chicago, Illinois More info | Jan 23, 2011 22:51 | #11 The reason is ... even though you have a slightly less noisy image at 100, at 400, you get more ambient light for the same setting. At ISO 100 the room is gonna be dark. At ISO 400, you'll get lights in the background NOT covered by the flash. Gives a more evenly lit look.
| Latest registered member was a spammer, and banned as such! 2695 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
