Thread started 23 Jan 2011 (Sunday) 19:16
Metering in center or AF point?
nate42nd
Jan 23, 2011 19:16 |  #1
In my 7D manual it clearly says "evaluative" metering does what it's supposed to do but when I use single point AF and choose an AF point in a darker or brighter area of the scene it adjusts the exposure. If the camera does not change position should the exposure not be the exact same when set to evaluative? It seems to change from the evaluative to spot. The AF spot. Is there some way to prevent this besides using AE lock? Thanks.
7D - - 17-55 F/2.8 - 24-105 F/4L - 100mm F/2.8 - 50mm F/1.8 - S95 / To see all click here
My Flickr (external link)
krb
Jan 23, 2011 19:20 |  #2
If you read the manual more closely, you will find that evaluative metering is "weighted" to consider the area around the AF point as being more important the the metering.
-- Ken
Gear list
nate42nd
Jan 24, 2011 09:49 |  #3
krb wrote in post #11700665 (external link)
Thanks Ken, I knew what it was doing....just missed that in the manual.
1,159 views & 0 likes for this thread
Latest registered member is gammy13
2188 guests, 346 members online
