rich_yau wrote:
TO answer the thread topic above, nightime sports is hard!!
Boy is that an understatement. High Schools are not known for great lighting in their stadiums, to say the least, and if you shoot the same field you will find dark spots. Just looking from field level, it may be kind of hard to see but, if you can get up in the press box/announcers booth, you will see it clearly.
Another problem you have to deal with, if the play is on the far side of the field, you want want the lens opened up all the way. Ok, so you are at 2.8 or 4.0, whatever your lens will go to, and then the play comes running your way. Now your flash will overexpose that tackle 10 yards away from you,blowing out the visiting teams white uniform.
The best advice I can give is, pick your shots. Your not going to get everything on everyplay, unless your shooting ambient light and then you will still miss stuff, so anticipate when the long pass may happen. Never, ever be anywhere near the line of scrimmage from a side view. You will miss the long pass downfield for a TD, or the interception that turns the game around. This year I have about 3 interceptions right dead across from me and a couple receptions and this reception last week.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
The line of scrimmage may be at the far end 35 and your at the opposite 35, the run thru the line by the RB may be loose and not that great of a shot but, if he breaks loose and comes down your sideline, in front with 2 or 3 defenders chasing him on the way to a TD, you'll have a great shot.
Same goes if they have a long pass that is for a TD. If your 30 yards away from the line of scrimmage, chances are you will be in position to get a good shot of the receiver going up for and catching the pass. Trust me it will be a better seller than the one of the guy running thru the line from a side view with no less than 4 players in the way.
Occasionaly you will want to be at the line of scrimmage to get a shot of the linemen in their down position but, for the most part, be ahead of the line of scrimmage when your team is on offense, and behind the offense when your team is on defense. Unless of course your think there may be a long pass downfield, then get down there for the INT.
On shooting sports...If you see it happen then you didn't get it.
