Thread started 25 Jan 2011 (Tuesday) 05:32
Great, just bloody great!
pilsburypie
Jan 25, 2011 05:32 |  #1
Had 2 specs of dust on my sensor that only ever showed up when against a light sky. No real problem, just niggled me. So, £12 on a Giotto Rocket blower, a good clean and dust of the camera, surrounding work area, pumped the Rocket blower 20 times to ensure no dust is caught inside, then 4 good blows on the sensor.
Take a test pic of the sky at f8 and it looks like I've used the body as an ash tray. AAAAAAGGGGHHHHHHHH! I'd say damn near unusable unless I want to spent 20 mins on each photo clearing up splodges.
So now going to have to buy some eclipse solution and swabs to sort this bloody mess out. Can't wait for the drama that unfolds then! Look out for my next post "Buggered up my sensor - What new camera to buy":(
Mark
SuzyView
Jan 25, 2011 05:43 |  #2
Sorry, for the dust bunnies, but the sensor cleaning isn't all that bad. Expensive, yes. The Eclipse and swabs cost around $80 US for a year's supply. It's easy to do, just costly. When you do sit down for the clean up, just remember to glide the swab and if you need to do the corners again, that's okay.
5DIV, SONY a7iii, 7D2, G12, M100, M50, 5 L's & 2 Primes, 25 bags.
philwillmedia
Jan 25, 2011 05:50 |  #3
pilsburypie wrote in post #11709921 (external link)
...I'd say damn near unusable...
How bad is that?
Show us a pic.
Regards, Phil
2013/14 CAMS Gold Accredited Photographer | 2010 & 2011 V8 Supercars Aust. Accredited Photographer | 2008, '09, '10 South Aus. Rally Photographer of the Year | Catch Fence Photos - 2009 Photo of the Year (external link)Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office" | www.freewebs.com/philw​illmedia (external link)
onick
Jan 25, 2011 05:51 |  #4
this is the post i make about the same situation:
https://photography-on-the.net …p=11709916&post​count=6871
i think this is where i messed things up, blowing the inner wall ands ending up with more, dust/dirt/oil from the mirror section on sensor.
fortunately mine is under warranty and taking it to canon servicing center tomorrow for cleaning.
Canon EOS 6D II | Canon EOS 550D | 18-55mm IS | 55-250mm STM | Rokinon 14mm F/2.8 | 35mm f2.0 IS | 50mm f1.8 | 135mm f2.0 L | YN-568EX II
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Jan 25, 2011 05:52 |  #5
How did you blow out the sensor box? I always do the procedure with the camera opening facing downwards. If you do it facing up, you just blow everything around inside (even along the sides) and most of it will resettle.
For Sale: 2x Teleconverter
For Sale: Sigma USB Dock
stevewf1
Jan 25, 2011 05:53 |  #6
Digital SLRs... Expensive... Dust on the sensor... Can be a BIG problem... There HAS to be a better way to prevent this...
When will the camera manufacturers finally address this problem?
Steve
pilsburypie
Jan 25, 2011 06:24 as a reply to  @ stevewf1's post |  #7
When I say I pumped the blower 20 times to make sure no dust was caught inside, I meant in the blower. I pumped the blower 20 times away from the camera to ensure no dust was inside the rubber bulb.
I only did 4 puffs inside the camera all aimed at the sensor with the camera body facing downwards so gravity aids as recommended.
When I say unusable I am being a little dramatic. I also feel like I could get a hammer to the camera right now, but I won't;)
I shall be getting cleaning solution and swabs and trying to fix the mess!
Some may have had better luck with a blower to clean their sensor, but from "my" first hand experience, being careful to ensure the greatest possibility of success I can strongly suggest:
DON'T USE A BLOWER TO CLEAN YOUR SENSOR!
Mark
philwillmedia
Jan 25, 2011 06:34 |  #8
pilsburypie wrote in post #11710043 (external link)
...When I say unusable I am being a little dramatic...
Still wouldn't mind seeing what it looks like
Regards, Phil
pilsburypie
Jan 25, 2011 06:43 |  #9
Here you go Phil.
Onick - not as bad as yours. Well done you beat me!
edit: That isn't a hair ball at the bottom of the frame!
Mark
phreeky
Jan 25, 2011 06:43 |  #10
I don't have a problem with the 7D, I make it do its own sensor clean about once a month but that's it. The 20D is a bloody dust magnet in comparison, I ended up getting a wet clean solution for it and once I got used to it I'd do it before each shoot that'd involve lots of sky (birds, airshow, etc).
For other types of shots I'd not bother, it's pretty hard to spot without a sky in the image IMO (or something similar).
VinnieJ
Jan 25, 2011 06:46 |  #11
An excuse to buy whatever new pro body comes out this year! :lol:
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Jan 25, 2011 06:48 |  #12
How far did you insert the blower nozzle? Also, one shouldn't blow around the sensor ever. A person should just insert the nozzle tip right at the mount point, maybe a tad farther, and blow the sensor only. There lubricants and other material around the sensor, and they risk blowing small droplets back onto the sensor, thus requiring a wet cleaning. I am sure you did this correctly (4 puffs, only at sensor), this is info for others that may have never used a blower, then read this thread only to walk away thinking a blower is not appropriate, when in actuality it is.
I have used a blower on 10+ different bodies and never had an issue. It always cleaned off the dust. It appears to be droplets in your sample, perfectly round and small. Dust particles are usually not so perfectly round, especially at f11. Somehow something foreign moved from the surrounding area and landed on the sensor. If another few bursts won't dislodge these, it adds credence to the fact that this is probably a liquid of some sort.
Martin.D
Gallery: 147 photos
Jan 25, 2011 06:50 as a reply to  @ TeamSpeed's post |  #13
Cheaper option, Sensor Klear Loupe Kit... I have one and use it all the time...
Web Site (external link)
Facebook (external link)
Instagram (external link)
Canon 5D Mark IV + Canon 90D + Glass
DetlevCM
Jan 25, 2011 07:32 |  #14
Cheaper than "Eclipse" - 100% Isopronaol from the pharmacy.
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
MHO
Jan 25, 2011 07:37 |  #15
Yeah, sorry to hear that dude.
I think most people who try to dust off their camera sensor get the same thing.
I for one have and it it just frustrates you more!
I have even gone through washing the blower's insides but they seem to generate dust and particles!
Damn Blowers! :p
MHO Photography on Flickr (external link)
Facebook Page (external link)
5D2 & 1D2n & Some Lenses
7,858 views & 0 likes for this thread
Latest registered member is csbokeh21
1615 guests, 309 members online
