Thread started 25 Jan 2011 (Tuesday) 12:42
Do I need more power? Question about a specific situation.
Village_Idiot
GREATEST POTN MEMBER EVER
Jan 25, 2011 12:42 |  #1
I'm up for a job shooting a roller derby team, depending on if they can afford my measly quote.
For singles photos I want to do the photos outside and I'm thinking my setup is going to be something like this:
I want two lights with strip boxes at 45 degrees behind the subject to the left and right to give a nice strong highlight. I'm going to have a hairlight coming from behind the subject. The main light is going to be a beauty dish or a silver umbrella that's closed a bit to focus the light.
I have a 1200w/s Speedotron pack and a 400w/s pack. I'm wondering if this is going to be enough to give me a slightly darker sky? I have a 6 stop ND and I'm going to be purchasing a 3 stop ND shortly. Last time I shot with the 400w/s pack with one light in a beauty dish with the 6 stop, I was still having problems overpowering the sun.
I figure I'll have the 400w/s pack with one head providing the hair light and adjust the power as necessary. The 1200w/s pack will let me run one light at 600w/s and two at 300w/s. Does anyone have experience that tells them that this will be enough to darken a sunny sky with the main light, but provide a good highlight with the strip boxes if they're only running at 300w/s each, or will I need to possibly purchase another pack?
I'm going to test this out and try and get a good setup in the next couple of weeks. This shoot won't be until the weekend of February 19-21. I'm completely unsure as to what the weather is going to look like at that point, so I have to count on being able to overpower the sun if needed.
Just sitting here at work and wondering. If anyone has any experiences, ideas, suggestions, etc...I'd like to hear them.
My village called. I was told that they missed me.
Speedotron users, untie!
bobbyz
Jan 25, 2011 13:16 |  #2
Do you have a lightmeter? If yes it is so much easier to know what kind of exposure readings you get at the subject distance you envision for this shoot using the modifiers that you want. Use sunny 16 rule to get your ambient exposure. Then compare what your lights can do. You know how many stops your lights are above the ambient. You need ambient knocked down say 2-3 stops depending on how dark you want.
Even if you don't have a meter, just take some test shot and you know if you over power sun or not. Faster than anyone else telling you if you can do it or not, isn't it. We don't have your gear and strobe power readings don't mean much, IMHO.
Fuji XT-1, 18-55mm
Village_Idiot
Jan 25, 2011 13:36 |  #3
bobbyz wrote in post #11712033 (external link)
Unless some one has experience with a similar setup ;)
Wilt
Jan 25, 2011 17:29 |  #4
I side with bobbyz...take a reading at 10' with the 1200w/s pack with one head at 600w/s into whatever modifier you plan to use. Anything else is still a guess, since you would have no idea if my modifier was more efficient or less efficient than yours!
If the reading is not higher by 1EV than comparable daylight Sunny 16 expectation (f/16 at ISO100), no 'darkening of the sky' will take place. If you can get f/16 reading, since you can set shutter to 1/200 and still capture all the flash output while darkening the sky, you could accomplish same in real situation.
The ­ Loft ­ Studios
Jan 25, 2011 18:52 as a reply to  @ Wilt's post |  #5
When using a modifier such as a softbox or umbrella, you'll need at least 1200ws of power to overpower the "noon" sun (assuming you're doing full length shots of the subject and your light is 8' to 10' away...), with a beauty dish - about 800ws.
MARK
Wilt
Jan 25, 2011 19:26 |  #6
The Loft Studios wrote in post #11713941 (external link)
Different flashes have different efficiencies, but the above statement seems pretty consistent with my findings...
Dynalite M500 (500 w-s full pwr) would yield f/16 at 4' or GN64 -- in a 24"x36" softbox. The softbox used was losing about -1.25EV So using this setup I could overpower the sun only out to 4' light to subject.
bobbyz
Jan 25, 2011 21:10 |  #7
I would add to what has been said that using HyperSync or a camera which will let you sync fastser than typical 1/200 max sync speed also helps when overpowering the sun. I can easily do 1/500 on my 1dmk2 with mini/flex and AB800. So instead of 1/100 if I can do 1/500 I gained more than 2 stops, isn't it.
Here is one with AB1600 (640ws) at ISO50, 1/200, using AB beauty dish. Don't remember the exact power but pretty close to full.
IMAGE: http://www.bobbyzphotography.com/img/s8/v10/p856549968-5.jpg
AB3200 would be more flexible, I agree.
Note:- If you check exif, camera date is off. I just got my 5d then.
Fuji XT-1, 18-55mm
Village_Idiot
Jan 26, 2011 08:24 |  #8
Wilt wrote in post #11714080 (external link)
They're going to be single person shots, so I can pull the lights in closer, what I'm really worried about is if the two strip boxes at 300w/s are going to be enough to provide a rim light? I guess that's what you would call it.
I need another 1200w/s pack I think.
GenuineRolla
Jan 26, 2011 09:01 |  #9
wow....
Alright...I get can get the ambient to be pretty dark with my b800, shot through a beauty dish, on full power. You'll want to get your f/stop's up there, since you can only have 1/200th. ND filters aren't going to help one bit since they knock down the flash exposure as well.
So, you should be fine with the 400w head, even more so with the 1200w. with a b1600 on FULL, you should be able to get f/16 pretty easily....so with f/16 and 1/200th, that can usually knock down the ambient pretty well.
the 300ws for the rims will be fine, just have them on full power as well.
flickr (external link) | 40/60 Photo (external link) | Petey Photography (external link)| Canon 5D + 17-40mm f/4L + 50mm f/1.4 | 3x Alien Bee B800 | shuttrr.com (external link) - are you in?
bobbyz
Jan 26, 2011 09:38 |  #10
Use rim lights without modifier if you need more juice from them.
Fuji XT-1, 18-55mm
Village_Idiot
Jan 26, 2011 09:55 |  #11
GenuineRolla wrote in post #11717297 (external link)
wow....
I used the 400w/s pack with a Kacey beauty dish previously. Don't mind the tint, I believe it's from the ND. This was with the 6 stop B+W I have.
IMAGE: http://farm5.static.flickr.com/4111/5171206736_481bd38ef1_z.jpg
IMAGE LINK: http://www.flickr.com/​photos/cokronk/5171206​736/  (external link)
The dish was probably about 5', maybe 6' away and to the upper right. It's was a cloudless sunny day and you can still see plenty of light coming from the sun.
I'm using the ND so I don't have to push such narrow apertures. I'm also going to try and purchase a PW Flex Mini to see if I can get a faster x sync. I think they managed up to 1/250 with a 5D MKII. At that point, I can shoot a little wide and bump the shutter speed up to where I'm just starting to get a black bar and crop that in post.
The 1200w/s pack is going to be split at 600w/s for the main and 300w/s each for the sides. If it's cloudly out, I'll be that much happier.
bobbyz wrote in post #11717516 (external link)
What can I do to get a similar spread/control as a strip box. Barn doors?
Wilt
Jan 26, 2011 10:14 |  #12
Village_Idiot wrote in post #11717110 (external link)
If my 500 w-s in softbox resulted in f/16 at 4', 300 w-s at 2.8' should have the same f/16 output (a touch more, actually). Using a snoot rather than a stripbox for single portraiture would also help.
Village_Idiot
Jan 26, 2011 10:26 |  #13
Wilt wrote in post #11717721 (external link)
For rim lighting? I want something that highlights the length of the body. At least I think I do.
We're supposed to get almost a foot of snow tonight, so it's less than ideal shooting conditions right now. Maybe this weekend...
Wilt
Jan 26, 2011 10:35 |  #14
Village_Idiot wrote in post #11717775 (external link)
The type of light (snoot, strip) affects the type of lighting cast, but are all appropriate sources to rim lights, just as they are both employed for hairlight, depending upon the hairstyle and color of the subject.
Village_Idiot
Jan 26, 2011 11:04 |  #15
Wilt wrote in post #11717818 (external link)
Maybe I'm calling it wrong. I want the lights to run the length of the body like they do in this shot:
IMAGE: http://farm4.static.flickr.com/3170/2893340347_e0c9a4ca54_z.jpg
I don't see how a snoot could accomplish that since it's such a focused light. Do I have the vocabulary wrong? Is that not a rim light?
4,590 views & 0 likes for this thread, 6 members have posted to it.
517 guests, 156 members online
