Thread started 25 Jan 2011 (Tuesday) 20:04
Master flash disabled , only slave firing --> why preflash req?
datadump
Jan 25, 2011 20:04 |  #1
this could be a really basic question. i've always used generic flash with manual output modes and i have never owned two ETTL flashes until now so i'm playing around with ETTL master/slaves.
i have 580EXII as master, controlling a slave 430EX.
if in a case where i just want slave to fire, i disable master 580EX via disabling master per page 39 in the manual. but the master unit still fires... i dont get why?
it says in a small note in the page 39 that "it will still preflash to transmit wireless signals" to slave but i thought that was what the IR was for? so why does it need to send preflash?
datadump
thaking
Jan 25, 2011 20:06 |  #2
i don't have a setup like this, but my guess is to get ETTL for the slave the preflash is required...
Hoppy1
Jan 25, 2011 20:22 |  #3
It's not really IR, but semi-IR or near-IR. Which is what the ST-E2 master controller uses, but the 580EXII uses visible light (in multiple morse code like pulses fired at very high speed) that is filtered to near-IR by the slave unit's window.
If you like, in theory you can dim them down to near-IR with a filter but nobody bothers because they all go out before the shutter actually opens so don't effect the exposure.
5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
datadump
Jan 25, 2011 20:38 |  #4
thanks for the info. so everything is working ok. surprisingly this wireless system works REALLY well. i thought it was line of site stuff so i always used cheap radio triggers for my sunpak manual flashes... but i finally collected two canon flashes and started working with these and i'm impressed.
datadump
1,485 views & 0 likes for this thread, 3 members have posted to it.
1463 guests, 136 members online
