Thread started 26 Jan 2011 (Wednesday) 11:50
Spyder pro and florescent lighting?
dou_b_14
Jan 26, 2011 11:50 |  #1
I just opened my new studio and did a test print but it didn't match what I saw on my monitor. I didn't have that problem at home. I use the huey to calibrate my monitor and worked fine before. For some reason I can't get it to give me a good calibration in my studio with florescent lights. Will the spyder give me a better result?
Canon 5d w/grip / canon 7d/ canon G1X/ 24-70mm 2.8 L/ 17-40mm L/ 50mm 1.4/(2)580ex/ pw's (3) /st-e2/ (2)cp-e3 battery pack/ abr800/ vagabond 2/ calumet genesis 200w(2)/
ChasP505
"brain damaged old guy"
Jan 26, 2011 12:17 |  #2
dou_b_14 wrote in post #11718310 (external link)
...I didn't have that problem at home. I use the huey to calibrate my monitor and worked fine before. For some reason I can't get it to give me a good calibration in my studio with florescent lights. Will the spyder give me a better result?
If the Huey worked fine before, there's no reason it wouldn't continue to work fine. Why not just turn the lights off when calibrating the monitor?
If you have to work under fluorescent lighting, make sure they are good quality bulbs/tubes with 5000K color temperature. GE makes some decent tubes and it's easy to find CFL bulbs with 5000K temperature and fairly high CRI rating (85+). CRI is Color Rendering Index.
The lighting that you view and display your prints under is a different issue.
I saw this blog article recently and it shows a great light setup:
http://www.ronmartblog​.com …f-neils-print-studio.html (external link)
Chas P
dou_b_14
Jan 26, 2011 12:24 |  #3
I wasn't sure if they sold 5000k temperature lights that would fit. So I'll head to home depot later and see if I can find them. I use 5000k lights in my house so I think that's the problem in my new studio.
968 views & 0 likes for this thread, 2 members have posted to it.
2695 guests, 149 members online
