Thread started 27 Jan 2011 (Thursday) 14:37
Saving picture in CS5.
V-Wiz
Joined Sep 2009
Jan 27, 2011 14:37 |  #1
Okay i feel stupid asking this but how do you guys save your edited pictures when your done in CS5. I save multiple ways but i want to know what you guys do. I just saved RAW images and now its saying im out of RAM. WTH.
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
Sdiver2489
Joined Sep 2009
Jan 27, 2011 14:46 |  #2
You can't save a RAW image, you can have a "sidecar" file that stores information as to what changes you made, but you cannot write a RAW file with your changes included, otherwise its not RAW anymore.
As for me, I save my images from my 50D to a quality of (I believe) 87 in Lightroom. This pegs a "normal" 50D image usually around 4-5MB.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
stsva
Gallery: 45 photos
Jan 27, 2011 14:51 |  #3
I use "save as" and it's almost always as the highest quality JPEG, "baseline optimized," although I'll occasionally save a complexly edited image as a PSD file with layers in case I want to be able to either see what I did in the layers or further edit.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
Sdiver2489
Joined Sep 2009
Jan 27, 2011 15:02 |  #4
stsva wrote in post #11726350 (external link)
If I do a save in PS5 I'll usually use quality 8-10 depending on the file size. I find it virtually impossible to see any difference in that range using baseline optimized.
Gear:
stsva
Gallery: 45 photos
Jan 27, 2011 17:18 |  #5
Sdiver2489 wrote in post #11726407 (external link)
Probably right, but I just go ahead and blast up to 12. I've got plenty of room left on my hard drive, so I figure why not.
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
Sdiver2489
Joined Sep 2009
Jan 27, 2011 17:29 |  #6
stsva wrote in post #11727094 (external link)
Oops I got my scales mixed up. Forgot that PS5 used a 1-12 scale. I typically use 10, sometimes higher if its an image with little noise and/or detail
Gear:
tonylong
...winded
Gallery: 60 photos
Jan 27, 2011 18:55 |  #7
V-Wiz wrote in post #11726252 (external link)
OK, there is a question here -- you say you are getting an "out of RAM" message -- is that exactly the message you're getting? If it is your problem is less with the file type and more with either too little memory or some related problem.
But if your problem is disk space, you should be clear of that and make some forward plans for your image library, such as picking up an external drive for long-term storage and also (this can be important) installing a large internal "data drive".
In other words your file format won't stop either problem in the long run since you are getting the error in the "here and now".
Tony
V-Wiz
Joined Sep 2009
Jan 31, 2011 10:53 |  #8
Ya thats what i normally do, and i just call the saved file something else. I think this last week i used Save As and it actually made changes to the RAW file to. i dont know why, i think i may have done something.
V-Wiz
Joined Sep 2009
Jan 31, 2011 10:55 |  #9
tonylong wrote in post #11727703 (external link)
Thank you, i do have space on the computer, but i think i was saving RAW images. after 10 or so images it said out of RAM. I tried other photos and it was okay. Im not sure what i did. lol, ill have to mess with it. Thanks.
ChasP505
"brain damaged old guy"
Jan 31, 2011 11:47 |  #10
V-Wiz wrote in post #11748850 (external link)
What you're describing to us is a disaster waiting to happen. Can you afford to lose all your photos?
Chas P
V-Wiz
Joined Sep 2009
Jan 31, 2011 14:25 |  #11
okay so im working on some photos right now and when i "save as" it creats a JPEG file which is cool, but it also makes the changes to the RAW file too. So when i open the RAW file the editing i made to it. Why, i dont want the RAW to change. THank you.
tonylong
...winded
Gallery: 60 photos
Jan 31, 2011 14:28 |  #12
No, hang on here.
When you say your Raw file what exactly are you talking about? Is it a file with a .cr2 extension?
Tony
V-Wiz
Joined Sep 2009
Jan 31, 2011 14:37 |  #13
tonylong wrote in post #11750083 (external link)
No, hang on here.
Yes Sir, when i open Mini Bridge the RAW file does read Cr2 at the end of the photo number. Plz help :o
stsva
Gallery: 45 photos
Jan 31, 2011 15:04 |  #14
V-Wiz wrote in post #11750138 (external link)
When you first open the .cr2 file in Adobe Camera Raw (ACR) to bring it into Photoshop, any changes made in ACR are saved, so that the next time you open that same .cr2 file by default it will have any changes previously made in ACR already "done." This has nothing to do with saving files in Photoshop, it's the default way ACR is set up to work.
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
tonylong
...winded
Gallery: 60 photos
Jan 31, 2011 16:14 |  #15
Yeah, we need to distinguish between editing in Camera Raw and editing in the Photoshop editor. Camera Raw won't change your Raw file, but it will save an xmp "sidecar" file with all your Camera Raw edits. So that may be what you are seeing. The thing is you can change all that back simply by hitting the Reset button in Camera Raw.
When you open a Raw file from Camera Raw into the editor, you are no longer working on the Raw file, the image has been "rendered" into what is basically a bitmap image and the edits you make on the image in the editor can only be saved as an image file such as a jpeg, a tiff, or a psd (or other supported file types) but these edits will not affect the Raw file.
So, when you use Save As to create a jpeg, the jpeg will show the combined edits done in Camera Raw and in the Photoshop editor. When you go back to the Raw file, it will show the adjustments made in Camera Raw -- maybe that's what you are seeing and just don't understand what's going on. Just realize that you can click the Reset button and go back to the beginning.
Go ahead and try the Reset and get back to us.
Tony
5,047 views & 0 likes for this thread, 9 members have posted to it.
2863 guests, 156 members online
