Thread started 29 Jan 2011 (Saturday) 08:59
Help w/ 430EX getting too bright!
tonman23
Jan 29, 2011 08:59 |  #1
My Speedlite has been acting up recently
When I pop batteries in, it works just fine. After a little while, shutting it off, turning it back on, the flash becomes unusably bright! When I pop the batteries out and wait a minute before putting them back in, the flash will function properly again . . . for a little while
Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
Portfolio (external link)
McNair
Joined Nov 2010
Jan 29, 2011 09:02 |  #2
turn the output down?
5D MKII Sigma 50 1.4 Rokinon 85 1.4 24 1.4 LII 70-200 F4L 135L
http://www.flickr.com/​photos/husl/ (external link)
Fureinku
Jan 29, 2011 09:05 |  #3
clean the contacts between on the flash and camera hotshoe.. ettl may not be working properly
Gear List | Wish List |
tonman23
Jan 29, 2011 09:15 |  #4
McNair wrote in post #11736716 (external link)
turning the output down doesn't change anything. It's as if no matter when I do the flash fires as bright as it can.
tonman23
Jan 29, 2011 09:30 |  #5
Fureinku wrote in post #11736728 (external link)
problem occurs even when i have it on manual. once it decides it's going to be bright, there's nothing I can do to fix it besides pulling the batteries.
Austin.Manny
Jan 29, 2011 10:04 |  #6
tonman23 wrote in post #11736756 (external link)
Sounds like you have it either in Manual mode, full power, or in eTTL mode but the flash is not communicating properly with the camera (most likely caused by a bad connection) so it fires at full power.
1D Mk III | 450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
Canon 430exIII | LumoPro LP180 | Yongnuo YN-460 |
RF-603
Wilt
Jan 29, 2011 10:15 |  #7
tonman23 wrote in post #11736818 (external link)
It sounds as if the circuit board which regulates output is acting up...send it to Canon repair.
tonman23
Feb 01, 2011 20:05 as a reply to  @ Wilt's post |  #8
I took a part the base of the flash and found a black wire that was loose. After searching around I found where it goes here https://photography-on-the.net/forum/showthre​ad.php?t=932943. put it back together and the flash is working like new!
step 5 to be exact
4,497 views & 0 likes for this thread, 5 members have posted to it.
1076 guests, 105 members online
