Thread started 29 Jan 2011 (Saturday) 20:52
5DMII - Silent Mode
pbelarge
Joined Jun 2010
Jan 29, 2011 20:52 |  #1
I have changed the setting of the silent mode of my camera 3 different ways.
1. Mode 1
2. Mode 2
3. Disabled
It does not change anything. The shutter sounds identical in all 3 modes. The speed of the shutter is also identical.
What is the purpose of this mode?
Is it possible that this mode is not functioning in my camera?
just a few of my thoughts...
Pierre
Mike ­ K
Joined Apr 2001
Jan 29, 2011 21:03 |  #2
pbelarge wrote in post #11739742 (external link)
You have to be in Live View mode for Silent Shooting to be effective. In Live View the mirror is up and shutter is open to expose the sensor. Silent shooting then initiates the exposure electronically (absolutely no vibration) and end the exposure mechanically with the shutter closing. Mode 1 and 2 differ in the timing of reopening the shutter to resume Live View. Mode 2 couples the reopening of the shutter to the lifting of your finger off of the shutter button.
http://www.usa.canon.c​om …ArticleAct&arti​cleID=1906 (external link)
Live View Silent shooting is an improvement over mirror lock up for reducing vibration.
http://forums.dpreview​.com …rum=1032&messag​e=35473092 (external link)
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
pbelarge
Joined Jun 2010
Jan 29, 2011 21:27 as a reply to  @ Mike K's post |  #3
Mike
Thanks for the info.
I performed this function in live mode, and mode 2 definitely makes more of a difference, but it does not really silence the shutter, it slightly reduces the vibration.
Pierre
Dr.Pete
Jan 29, 2011 21:51 |  #4
Clearly I'm not a live view shooter since I had no idea my 5D2 had a silent mode. :o
Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
“Gear Is Good, Vision Is Better.” -- David duChemin
MikePrattPhotography
Jan 29, 2011 22:43 |  #5
ok quick question, technically, wouldn't you be able to use a faster shutter speed while using flash since there is no manual shutter?
www.michaeloliveri.net (external link)
http://blog.michaeloli​veri.net (external link)
Dr.Pete
Jan 30, 2011 11:54 |  #6
MikePrattPhotography wrote in post #11740318 (external link)
No, because the X-Sync speed is based on how fast the shutter can open/close to cover the whole image circle with respect to the duration of the flash.
What live view takes away is the mirror flap, which is irrelevant to the whole flash sync issue.
Mike ­ K
Joined Apr 2001
Jan 30, 2011 13:27 |  #7
flash with live view is a more complicated. With a Canon flash in E-TTL II, the mirror will drop as the camera goes through its "preflash exposure". Then the mirror will flip back up for the normal exposure. With a non-Canon flash in live view the flash will not fire. Read the email from Chuck Westfall of Canon at the bottom of this post:
http://krebsmicro.com/​Canon_EFSC/index.html (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jan 30, 2011 13:43 |  #8
pbelarge wrote in post #11739917 (external link)
Mike
It allows you to choose after the exposure when to allow the noisy portion of the cycle to occur...such as a point in a theater production when the sound level rises. And it will have eliminated the sounds of the mirror rising and the shutter opening, which are themselves rather noisy.
Mike ­ K
Joined Apr 2001
Jan 30, 2011 13:44 |  #9
Mike
Without live view, the mirror has to slap up and the mechanical shutter opens. After the exposure both shutter closes and the mirror returns so you can see again in the viewfinder. Higher frame rates and larger mirrors (ie full frame) means more mirror mass has to move faster, so there is more sound/vibration. With Live View in the 40D, S0D (presumably 60D), 7D, 5DII the mirror stays up the entire time, so mirror slap vibration & sound are altogether missing. In this regard Live View Silent shooting will always be significantly quieter than normal (viewfinder based) shooting as the mirror slap is the largest vibration in the exposure sequence. I saw a thread recently of a high speed video of an exposure showing this mirror slap and shutter action.
In all of these cameras the LV SS exposure is terminated with the mechanical shutter, which then reopens right away in Mode 1 or when you lift your finger off of the shutter button in mode 2. Thus the sound you hear is the shutter recocking and reopening after the exposure. Mode 2 simply spreads out the sound over a longer time making it less intrusive. Note that the shutter closing and reopening occur at the end of the exposure, thus its vibration contribution to the actual shot will be nil, whereas the mirror slap and shutter opening occur just before the exposure begins.
apersson850
Jan 30, 2011 20:36 as a reply to  @ Mike K's post |  #10
You can use non-E-TTL flash guns in live view too, but you have to manually set the camera to disable silent shooting first. When you put on an E-TTL compatible flash, it will disable the silent modes automatically, without you seeing it happen.
Anders
3,384 views & 0 likes for this thread
5DMII - Silent Mode
Latest registered member is Snap Dragon
530 guests, 246 members online
