Thread started 29 Jan 2011 (Saturday) 22:48
need help with Sigma 150-500 and 1d mkiv
skater911
Jan 29, 2011 22:48 |  #1
So I just got a sigma 150-500 and am looking for some pointers. I took it out last week to get some photos of some otters in la jolla. All ss were between 1/500 and 1/800 and I was at F8, with IS on. Out of about 60 shots most were oof focus and the ones that were ok, were just that. What tips do you all have? I didn't have my tripod so they were all handheld at a range of about 350-500mm. I shot them in one shot, should I have used ai servo instead? I am still learning about the awesome and complex af as compared to the 5d mkii. I didn't post any photos as well they will just show you they are oof. Thanks for any info, and when I did a search I couldn't find much of anything useful.
Nikon D850 l Nikon 28 1.4E l Nikon 50 1.8 g l Nikon 24-120 F4 l Tamron 100-400 l
themadman
Jan 29, 2011 23:45 |  #2
Not to sound stupid, but have you tried some kind of controlled shot? If you don't have a tripod do you have a table indoors you can just rest it on?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
m.c.chavez
Joined Nov 2010
Jan 29, 2011 23:54 as a reply to  @ themadman's post |  #3
was it hot outside?
heat waves REALLY affects 40mm and beyond.
Filters are like Condoms ... Protection at loss of some quality.
AbPho
Jan 30, 2011 00:03 as a reply to  @ m.c.chavez's post |  #4
Have you ever used a telephoto before? Just asking because I do not see one mentioned in your signature. I have to 120-400 and had the Canon 100-400L and found that I needed to slow down a little and give the lens time to focus and to get the OS (IS) up to speed. I am not talking much time. Just a little more than what I was used to when shooting with a wider lens.
For your focal length range I think the shutter speed was adequate. AI Servo might not be that great if you cannot keep pace with your moving target. Or if you have AI Servo on and briefly move your enabled focal point off the subject. How fast do otters move?
Put tripod or table top test is a good way to see if the lens is off.
I'm in Canada. Isn't that weird!
cacawcacaw
Jan 30, 2011 00:20 |  #5
m.c.chavez wrote in post #11740573 (external link)
was it hot outside?
As does dust, haze, fog, spray, exhaust, etc.
I've had improved results with back-button, single-point, and AI Servo focus settings.
Replacing my Canon 7D, Tokina 12-24mm, Canon 17-55mm, Sigma 30mm f/1.4, 85mm f/1.4, and 150-500mm with a Panasonic Lumix FZ1000. I still have the 17-55 and the 30 available for sale.
artyman
Sleepless in Hampshire
Gallery: 17 photos
Jan 30, 2011 03:03 |  #6
Using a long lens for the first time takes getting used to, as suggested a controlled shot will determine whether it's you or your settings/lens. 1/500 1/800 is just about fast enough when you consider you are working with an effective focal length of 750mm. A tripod or monopod will help you.
Ken
skater911
Jan 30, 2011 03:29 as a reply to  @ artyman's post |  #7
I have used a telephoto lens before just not at the 500 range. I had the 300 with a 1.4 on mt 5d. It wasn't that really warm, about 75 degrees, come on it's winter here. :) I will try a couple of controlled shots and post one or two of them tomorrow. As for the subjects moving, they were fairly still as they were on a reef. Thanks for the suggestions thus far.
FlyingPhotog
Cream of the "Prop"
Jan 30, 2011 03:49 as a reply to  @ skater911's post |  #8
You can have "heat haze" in the dead of winter in Fairbanks if the sun is out.
500mm is significantly more reach and more compression so atmospherics become more critical.
Jay
DreDaze
Gallery: 49 photos
Jan 30, 2011 03:51 |  #9
regardless of if the picture is out of focus or not...it usually helps to post one with exif intact...if they were moving though AI-servo would probably be better...you don't have any sort of filters on the lens, do you?
Andre or Dre
gear list
Instagram (external link)
KVN ­ Photo
Joined Jun 2010
Jan 30, 2011 06:53 |  #10
Is it possible that it has front focus or back focus issue?
60 OOF shots is a big number, at least for me.
X-Pro1 + 18-55 f/2.8-4 OIS + 55-200 f/3.8-4.5 OIS
TS-E 24 f/3.5L II + XF 35 f/1.4 + XF 56 f/1.2
Sony RX100 II + G12
Travel the world!
huntersdad
Jan 30, 2011 07:08 as a reply to  @ KVN Photo's post |  #11
Mine had to go back to Sigma. They returned it saying nothing was wrong but it magically worked better. Try a controlled test.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
skater911
Jan 30, 2011 09:41 |  #12
KY707 wrote in post #11741493 (external link)
I am going to test it today, I hope it doesn't have to go to sigma. I have heard it takes a long time to get your lens back. I will post a shot today.
skater911
Jan 30, 2011 14:31 as a reply to  @ skater911's post |  #13
Here are a bunch of controlled shots, tripod on the "sho" of the street sign. Oh for the previous posts, there wasn't a filter on at the time before and none now. (admittedly I may have not been using the "os" when taking the original photos.) When I took out my lens it was off. Either it was off the whole time or I hit it on accident and turned it off.
150 @ f6.3
150 @ f8
150 @ f10
200 @ f6.3
200 @ f8
200 @ f10
300 @ f 6.3
300 @ f8
skater911
Jan 30, 2011 14:36 |  #14
300 @ f10
400 @ 6.3
400 @ f8
400 @ f10
500 @ f6.3
500 @ f8
500 @ f10
FlyingPhotog
Cream of the "Prop"
Jan 30, 2011 15:12 |  #15
Don't see an issue with any of the above.
Little bump in Contrast and some Sharpening and you're good to go by my eye.
Jay
2,446 views & 0 likes for this thread, 12 members have posted to it and it is followed by 2 members.
1354 guests, 179 members online
