Thread started 30 Jan 2011 (Sunday) 13:01
hp monitor
charlie_merrifi
Jan 30, 2011 13:01 |  #1
im being givin this monitor. Will it be a good editing monitor. http://h10025.www1.hp.​com …363837&key=null​&site=null (external link)
Canon 5D classic, Canon XS, Sigma 24-70 2.8 HSM, EF 50mm 1.8 II, EF-S 18-55mm f/3.5-5.6 IS Lens,Canon EF 75-300mm f/4.5-5.6 III, Sigma Ef-500 DG super flash, Sigma EF-530 DG Super Flash
toxic
Jan 30, 2011 13:56 |  #2
It's a TN panel. The only way to find out if it's any good is to calibrate and test it, there's no easy way to tell a good TN panel from a average or crappy one.
charlie_merrifi
Jan 30, 2011 14:16 |  #3
Yeah u know list price new is over 400
ChasP505
"brain damaged old guy"
Jan 30, 2011 14:32 |  #4
charlie_merrifi wrote in post #11743478 (external link)
May be true... before prices of LCD monitors and TVs fell through the floor. You can now buy something like this for about $100 USD. Don't waste your time with it. Invest in an IPS paneled 23" monitor for $200-$250.
Chas P
charlie_merrifi
Jan 30, 2011 15:04 as a reply to  @ ChasP505's post |  #5
Its being givin to me. So im not paying anything for itI
bohdank
Jan 31, 2011 07:40 |  #6
If you intend to use it for image editing, even free is too expensive ;-)a
charlie_merrifi
Jan 31, 2011 15:46 |  #7
Gotta be better than my old crt that has to be calibrated every ten minutes
charlie_merrifi
Jan 31, 2011 17:50 |  #8
Im curious as to why its so bad
ChasP505
Jan 31, 2011 18:29 |  #9
charlie_merrifi wrote in post #11751405 (external link)
Well... It's not so bad if it's all you have for the time being.
TN paneled LCD monitors have a limited viewing angle range compared to IPS types. This means that with minimal change in your viewing angle, the screen radically shifts in color and contrast quality.
Most TN paneled monitors are designed and engineered to deliver very bright, punchy colors, very suitable for multi-media entertainment, but not for photo editing.
Also, even if you attempt to hardware calibrate them, by design, they often can't be set to a low enough luminance level. Trying to hardware calibrate some TN paneled monitors introduces issues that weren't even even there before, like weird color casts and banding in gradients.
The positive side... You can sometimes "eyeball calibrate" a TN paneled LCD to a setting which is usable until such time as you're ready for accurate color.
http://www.pchardwareh​elp.com/guides/lcd-panel-types.php (external link)
http://www.tftcentral.​co.uk/specs.htm (external link)
Chas P
charlie_merrifi
Jan 31, 2011 23:53 |  #10
Ok thanks. I tried to calibrate it and it showed no change whatsoever. Even when i adjusted gamma and such in my calibration software. And i did notice the viewing angle. Unfortunatley its the best i have for now
1,849 views & 0 likes for this thread, 4 members have posted to it.
hp monitor
936 guests, 147 members online
