Thread started 31 Jan 2011 (Monday) 10:42
Memory card formating
ranger50
Joined Nov 2010
Jan 31, 2011 10:42 |  #1
I have been useing a Sandisk 8 GB extreame Pro, class 10 SDHC card in my 60D. I reformat the card each time that I download my images to the computer and delete them from the card. I reformat the card in the camera. Is this a good practice? Are you doing the same? just curious.
EOS 60D/ 70-200L/ Sunpak PF30X/ Sunpak 6600PG platinum Plus ball head Tripod 59.95 / Pelican S.S. Large Military Camera case
It's better to have it and not need it, Than to need it, and not have it.;)
gjl711
Jan 31, 2011 10:45 |  #2
Seems redundant. Why not just format in camera and skip the format in the PC? or just delete them and format once in a while.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
led ­ hed
Jan 31, 2011 10:49 |  #3
^, yep, i download my images to pc, then reformat IN camera, done!
Rob - "a photographer is a painter, in a hurry!"
Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS
ranger50
Joined Nov 2010
Jan 31, 2011 10:51 |  #4
gjl711 wrote in post #11748789 (external link)
I think maybe I put that the wrong way. I only format in the camera. Sorry for the misunderstanding.:o
shutterpat
Gallery: 33 photos
Best ofs: 11
Jan 31, 2011 10:53 |  #5
same here...format in camera.
uOpt
Jan 31, 2011 10:56 |  #6
ranger50 wrote in post #11748775 (external link)
It's useless. The format only writes to an insignificant percentage of total sectors on the card. To make things worse, by doing this you wear out those sectors, and they are the most import sectors. You don't want the sectors holding important filesystem metadata first.
And then there is the problem that your camera is probably least able to notify you of errors that it did encounter during formatting.
IMHO you should either do nothing, or else if you want to test the card then you write to all sectors and read them all back. On a PC with good error reporting.
My imagine composition sucks. I need a heavier lens.
ben_r_
-POTN's Three legged Support-
Jan 31, 2011 11:02 |  #7
I reformat the card in my camera each time Im done downloading images. Yes its safe and if it works well for you its a great practice.
hairy_moth
Jan 31, 2011 11:09 |  #8
Normally, I have only formated cards once every several months or so, preferring instead to just delete all images after loading them into my computer... Starting yesterday I format each time I download.
Yesterday after taking about 50 shots, the computer refused to read my CF card. I have two different CF card readers, neither worked. I got an error message indicating that the card needed to be formatted before use, which I wasn't about to do because I needed those shots.
I finally had to put the card in the camera and plug the camera into the USB port (for the first time using this camera). That worked and I was able to download the images from the camera. Then I formated the card, removed it from the camera and placed it in the computer's card reader.. all is good.
7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr (external link)
uOpt
Jan 31, 2011 11:28 |  #9
hairy_moth wrote in post #11748942 (external link)
I would definitely retire this card.
alvezz
Jan 31, 2011 13:44 |  #10
i just delete all the images once transfered to the PC and not sure if i have ever formated. you never know if you want any you delete as the extreme pro cards come with a years subcription to the rescue pro software.
Shoot first, ask questions later!
myFlickr (external link)
Dr.Pete
Jan 31, 2011 13:47 |  #11
I once asked this question of NAPP tech support--they said that the reason lightroom doesn't have the option of formatting a card after import is because in-camera formatting is the best way to prevent corrupting the card.
Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
“Gear Is Good, Vision Is Better.” -- David duChemin
robtaylor22
Joined Nov 2010
Jan 31, 2011 13:56 |  #12
led hed wrote in post #11748818 (external link)
Ditto!
robtaylor22
Joined Nov 2010
Jan 31, 2011 13:59 |  #13
alvezz wrote in post #11749813 (external link)
Not a good practice. Reformat In-Camera on a regular basis. Most people with problems do what you are doing, deleting pictures. The Sandisk cards are good and may have saved your bacon. Reformat often in the camera.
DetlevCM
Jan 31, 2011 14:04 as a reply to  @ robtaylor22's post |  #14
Indeed - just read the card into the computer and format it in the camera, done.
Flash cells have a limited lifetime - now on cheaper flash that might be maybe 1000 writes per cell (8.000GB) - on better flash it can be up to 10.000 writes per cell (80.000GB) - while that's not something you will most likely reach using the card, but still there is no need to put extra wear on the card.
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
KVN ­ Photo
Joined Jun 2010
Jan 31, 2011 19:40 |  #15
Same here.
X-Pro1 + 18-55 f/2.8-4 OIS + 55-200 f/3.8-4.5 OIS
TS-E 24 f/3.5L II + XF 35 f/1.4 + XF 56 f/1.2
Sony RX100 II + G12
Travel the world!
6,174 views & 0 likes for this thread, 26 members have posted to it.
2877 guests, 169 members online
