Thread started 31 Jan 2011 (Monday) 17:19
Canon 17-40 f/4.0L hood and filters
uOpt
Jan 31, 2011 17:19 |  #1
Does the Canon 17-40 f/4.0L come with the hood?
Does the hood still fit if I put a filter on? If not what do I do?
My imagine composition sucks. I need a heavier lens.
george ­ m ­ w
Jan 31, 2011 19:15 |  #2
Yes it comes with a hood and yes you can use filters with the hood in place.
It comes with the ew-83e which is designed for use with FF cameras. If you are using the lens on a crop sensor camera, you can use the ew-83J which is a deeper hood giving more protection.
regards, george w
"It's also obvious that people determined to solve user error with more expensive equipment will graduate to expensive user error."
Dave N.
uOpt
Jan 31, 2011 19:30 |  #3
Hah!
Finally an excuse to get a 5D! Otherwise I would have to get a new hood, unacceptable.
Thanks for the info. I ordered one, my first L lens :)
jkokbaker
Jan 31, 2011 20:21 |  #4
I just got the same lens for my 5D, it's wonderful, better get the 5D, otherwise it is not a true ultra wide angle lens.
5D IV, Rokinon 14mm, Zeiss 21mm, Rokinon 24mm 1.4, Canon 24-105L, Speedlight 430EX II
Sunnysid3up
Jan 31, 2011 20:24 |  #5
I use it with my 50D. It works great. Good colors, sharp...etc.
To answer the original post I have both hood and filter on it.
Visit my flickr (external link)
| Nikon D700 | Nikon 50mm 1.4 | Vanguard Tracker LT-24 w/SBH-50 | +other stuff
uOpt
Feb 01, 2011 14:46 |  #6
Well, sure I will have to get the 5D.
On a related note, to properly use it on the 40D I need to get a EW-83J hood. The best way to do that is buying a lens that comes with it, no?
edge100
Feb 01, 2011 14:54 |  #7
uOpt wrote in post #11751238 (external link)
Yes and yes.
Street and editorial photography in Toronto, Canada (external link)
Mirrorless: Fujifilm X-Pro1
Film: Leica MP | Leica M2 | CV Nokton 35/1.4 | CV Nokton 40 f/1.4 | Leitz Summitar 50 f/2 | Canon 50 f/1.2 LTM | Mamiya 7 | Mamiya 80 f/4.0 | Mamiya 150 f/4.5 | Mamiya 43 f/4.5
How to get good colour from C-41 film scans (external link)
Digitizing film with a digital camera (external link)
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Feb 01, 2011 14:57 |  #8
It comes with an EW-83E. Not sure about using a different hood with it.
Doc Klepper in the USA
I
george ­ m ­ w
Feb 01, 2011 15:34 |  #9
The ew83J hood is the spec hood for the EF-S 17-55 lens. And I don't know about that "properly" comment. It's just that the "J" hood covers more than the "E" hood.
The ew83J works fine on the crop sensor bodies because the smaller sensor is not using that part of the glass out towards the edges. I use this hood when using the 17-40 all the time on my 1D2, and I used it on the 20D and 50D when I had them. The xxD bodies have an even smaller sensor than the the one series.
If you use the ew83J when on a FF body, you will get vignette at wide and near wide settings, so then it's time to put the smaller ew83E hood on.
regards, george w
Dave N.
jrscls
Gallery: 158 photos
Feb 01, 2011 16:10 |  #10
The hood designed for the 24-105 f4 IS L works fine on the 17-40 L when mounted on a crop body as well as the one described above that is designed for the 17-55.
Sony A1, 24-70mm f/2.8 GM II, 70-200mm F/2.8 GM OSS II, 200-600mm f/5.6-6.3 G OSS, 35mm f/1.4 GM, Viltrox 16mm f/1.8, 1.4X TC, Flashpoint flashes
x_tan
Gallery: 137 photos
Feb 01, 2011 16:29 |  #11
ALL L lenses come with a hood; so there is another excuse to get a L ;)
jrscls wrote in post #11758070 (external link)
Yes, I did it few time if I don't need the 24-105 and work. Just keep the eye on the hood to make sure it fits right into the position.
The original 17-40L on FF is useless to me.
Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
Sony α7r + Zeiss 1,8/55 FE
Nikon Coolpix A; Nikon F3 & F100 + Zeiss 1,4/50
Retiring  (external link)
sinjans
Feb 02, 2011 11:30 |  #12
You can get a different hood but its unneccessary.
Daffodil ­ Hunter
Feb 02, 2011 11:37 as a reply to  @ sinjans's post |  #13
Here you go.
magwai
Feb 02, 2011 11:39 |  #14
too small a hood will work but shield you slightly less well from light that won't hit the sensor (other than from internal reflections etc that you are trying to avoid, hence the hood).
too large a hood and you will see it in the picture.
4,620 views & 0 likes for this thread, 11 members have posted to it.
Latest registered member is EBiffany
1594 guests, 97 members online
