Thread started 31 Jan 2011 (Monday) 22:38
P67 mobo recall
CGsteve77
Jan 31, 2011 22:38 |  #1
So I'm putting together a new PC to run LR3 and CS5 on, interested in the new i5/i7's...then i go on the asus forums and read this:
http://vip.asus.com …67&page=1&SLang​uage=en-us (external link)
no wonder why I couldn't find any of these on newegg - sry if repost
6D | 5DII | Sony RX100 | 35L | 70-200L f/2.8 IS II | 580EX II
BeritOlam
Jan 31, 2011 23:37 |  #2
CGsteve77 wrote in post #11753353 (external link)
Thanks! Hadn't seen that one pop up today....but sounds like it could be pretty substantial for all of you Sandy Bridgers out there.
A good reason why it's not always wise to buy something when it's brand spankin' new out the door!!
Blessed are the young, for they shall inherit the national debt. – Herbert Hoover
ni$mo350
Jan 31, 2011 23:45 |  #3
I know you already chimed in on my questions earlier Berit, but I have another question. Does this mean both the ASUS mobo's AND the Sandy Bridge CPU's are bust? Or was I just confused earlier and the CPU's are fine. I can deal with getting another P67 mobo from MSI or Gigabyte but I really want the i7 2600k.
-Chris-Website (external link)|| (external link)Facebook (external link)|| My Flickr (external link)|| Follow me!!! 500px (external link) || (external link) 5D mkii || 35L || 70-200 f/2.8L IS MKII || My bank account hates you all :cry:
Ultra
Feb 01, 2011 06:30 |  #4
I literally put together my new pc last night with the ASUS P8H67-M and found this out just a few minutes ago :(
Canon 5Dii+5D :35L 1.4: 70-200L 2.8 IS: 24-105L :Canon 100mm 2.8: 85mm 1.8: Canon 50mm 1.8
www.eYeWonderPhotograp​hy.com (external link)
MM# 413819
BeritOlam
Feb 01, 2011 07:08 |  #5
If you already have a P67/H67 board, the easiest work around is going to be simply use the 2x 6G ports....and bypass the 3G ports altogether.
Anandtech summarizes (external link):
Intel maintains that Sandy Bridge CPUs are not affected, and current users are highly unlikely to encounter the issue even under heavy loads. So far Intel has only been able to document the issue after running extended testing at high temperatures (in a thermal chamber) and voltages. My recommendation is to try to only use ports 0 & 1 (the 6Gbps ports) on your 6-series motherboard until you get a replacement in place.
OEMs and motherboard manufacturers are going to be talking to Intel over the next week to figure out the next steps. Intel plans to deliver fixed silicon to its partners at the end of February, however it’ll still take time for the motherboard makers to turn those chips into products. I wouldn’t expect replacements until March at the earliest.
If this is correct, then it sounds to me like the CPU's don't need anything remanufactured. It's only the boards that need to be fixed. But since the CPU is no good without a mobo, that's probably why Newegg and other places have pulled the processors as well.
mjmackinnon
Feb 01, 2011 08:08 as a reply to  @ Ultra's post |  #6
This only effects the 6 series motherboard southbridge chips. So it's a hardware issue on the motherboard. It only effects the sata2 ports.
So, if you only have 2 hard drives, you can plug them into the sata3 ports and all will be good. If you board has additional sata ports from a different vendor like Marvell or JMicron, then you can use them as well without problem.
This error will result in a new motherboard as the chip layout has changed. How the OEM vendors are going to resolve this is currently not known as Intel was obligated to do a global press release, and everyone found out at the same time. So the motherboard suppliers are now stuck having to figure out what to do while everyone who bought the boards are harping about getting a defective product.
The issue is a statistical one. so, it is not a guarantee that your board will fail, but over the 3 year lifespan of the board, a large enough group will fail. If you are looking to keep the computer for say 6 years, then your chances of failure increase significantly. But still not anywhere close to 100%
You have to now weigh the cost of ripping everything out and getting a replacement motherboard with the chance of failure. Hopefully they do it right and offer either a replacement coupon to buy a new board or upgrade to the Z67 chip that doesn't have the issue, rather than requiring you to send in your motherboard (at your cost) and they will ship you a replacement.
My Flickr (external link) - Canon EOS 5Diii | EF 50f/1.4 | EF 24-105 f/4L IS| EF 100-400L IS | EF 70-200f/4L |430 EX II | Elinchrom BX500Ri
Post Production: i7-2600k, Win7, iMac 27 i7 | Adobe Photoshop CS6
YP5 ­ Toronto
Feb 01, 2011 08:30 |  #7
it deals with your 3gb sata ports.... nothing else.
Some manufacturers will offer a replacement of the board... or a pci-e sata card to "replace" the ports tha "may" fail over time.
Its a big deal, but not a huge failure.
Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
996gt2
Feb 01, 2011 11:15 |  #8
YP5 Toronto wrote in post #11755227 (external link)
I have a Sandy Bridge 2500K based system that I built earlier this month and this problem isn't a huge deal for me. I just moved my SSD and HDD to the SATA 6 Gbps ports which are unaffected. In a month or two, major motherboard manufacturers such as Asus and Gigabyte should issue recalls for the affected boards.
Buy/Sell Feedback
5Dc, 50D, Tokina 12-24 f/4, Tamron 28-75 f/2.8, Sigma 50mm f/1.4, 430EX
macroshooter1970
Feb 01, 2011 11:47 |  #9
The flaw is not in the Sandy Bridge processors themselves, Intel said, but in a support chip that is needed to connect the new microprocessors to the rest of a system.
The problem can cause some connections to disk drives and DVD drives to degrade over time, potentially interrupting the flow of data from those devices, the company said.
Read more: http://online.wsj.com …815876.html#ixz​z1CjLmuc4H (external link)
bohdank
Feb 01, 2011 13:41 |  #10
I wonder how this affects laptops. I just bought an I5 a few days ago.
MCAsan
Joined Jun 2010
Feb 01, 2011 18:38 as a reply to  @ bohdank's post |  #11
A Sandy Bridge i5? If so, ask the maker of the laptop.
bohdank
Feb 01, 2011 19:06 |  #12
Yes, an Acer.
DisrupTer911
Feb 01, 2011 20:00 |  #13
Then your affected.
Intel Sandy Bridge CPUs utilize Cougar Point Southbridge chipped motherboards.
Its the only chooser available for SB CPUs.
www.vividemotionphotograph​y.comexternal link
bohdank
Feb 01, 2011 20:14 |  #14
There is nothing on their website concerning this issue, yet. I will email them for clarification.
MCAsan
Joined Jun 2010
Feb 01, 2011 22:37 as a reply to  @ bohdank's post |  #15
You might want to see what port the laptop uses for the 1 or 2 hardrives. I would bet it is 3GB, not 6GB. If so.....you need a replacement.
7,828 views & 0 likes for this thread, 19 members have posted to it.
P67 mobo recall
1061 guests, 171 members online
