Thread started 01 Feb 2011 (Tuesday) 19:22
Camera, lens or operator?
Hartley
Feb 01, 2011 19:22 |  #1
Hi Guys,
I'm sure someone can give me an idea about what's going on here. I have a T1i, and the Canon EF-S 18-200 lens - and I'm not really happy about the sharpness I'm seeing.
Here's an example sunrise from last weekend: first, the whole picture, no PP other than sized down to 600 wide from the original 4752 X 3168, shot at 1/15th, f9.0, ISO 100 :
Here is a piece of it, at full size, cropped to 803 X 616. :
Note that the trees along the ridge are just not sharp (the CA is understandable, given the lighting, that's not what's bugging me). The only PP I did here besides the crop was to drop the exposure a bit.
Here's a "full daylight" example - first, the whole picture, same size as above, 1/400 @ f 10, ISO 200:
IMAGE: http://i1022.photobucket.com/albums/af341/Hartleyg/Focustest3.jpg
And then an 800-square blowup from it:
IMAGE: http://i1022.photobucket.com/albums/af341/Hartleyg/Focustest4.jpg
Both of these were shot with AF on, on a tripod, IS off, in AP mode.
Am I expecting too much from my camera, would this be improved by a better lens, or is this just the operator (me) expecting too much?
Hartley J
Gear: 6D, 60D, 24-105L, 70-300L, Bigma, Tokina 12-24 18-55IS 430 EX II
xarqi
Feb 01, 2011 19:28 |  #2
Any filter?
What's your tripod?
r31ncarnat3d
Feb 01, 2011 19:31 |  #3
Not really sure here, but could this be caused by not correctly focusing to infinity? Also, what focal length did you use?
Canon 80D | Canon SL2 | Sigma 30mm f/1.4 ART | Canon 24mm f/2.8 STM
Sigma 17-50mm f/2.8 | Tamron 70-200mm f/2.8 VC
S.Horton
Feb 01, 2011 19:35 |  #4
The glass will make a difference. As for these shots, the first one will be soft because of what it is and the light you have. The second, that is haze, and that is normal. Rent a 24mm prime and a 24-70 l zoom if you can, take those out, and I think you will be sold on glass.
Sam - TF Says Ishmael
:cool:
Dr.Pete
Feb 01, 2011 19:45 |  #5
You certainly seem to be peeping deep enough that things like your choice of tripod and glass will play into the equation. Even wind can be an issue, especially with a rebel. This will be magnified by a long-ish lens without a tripod mount.
The cheapest route for you to make the leap to L is the 17-40 f/4 L. It's an amazing landscape lens that delivers some crazy-sharp images. Careful, though, because you'll likely find yourself addicted. In fact, the 17-40 was one of my first L's, and look what happened to me! ;)
Tools of the dark side | MacBook Pro/LR3/Photoshop CS5
“Gear Is Good, Vision Is Better.” -- David duChemin
S.Horton
Feb 01, 2011 19:46 |  #6
Btw clouds are moving more quickly than you think. Get your shutter speed up.
:cool:
Dr.Pete
Feb 01, 2011 19:50 |  #7
S.Horton wrote in post #11759431 (external link)
Good point. f/8 at ISO 200-400 would be helpful with minimal noise.
ckramos
Feb 01, 2011 20:09 |  #8
i'll vote for the smaller/closer aperature (setting one end to infinity) and/or better stabilization, while keeping the ISO at the least noisiest.
5d2 | 580ex ii | 35-70mm f3.5-4.5 | 50mm f1.4 | 17-40mm f4
pulsar123
Gallery: 82 photos
Feb 01, 2011 20:15 |  #9
This lens is not particularly sharp, especially away from the fame center. Also, at aperture ratios larger than f:8, diffraction effects start degrading the resolution. For this lens, the optimal resolution is reached around f:5.6-8. Check this review:
http://www.photozone.d​e …anon_18200_3556​is?start=1 (external link)
To eliminate AF issues, try to take a shot using LiveView and either "slow AF", or manual focusing. Also, if you are using long focal length (>100mm), you might improve the sharpness by using the "mirror lockup on" feature of your camera (of course, using a tripod).
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
S.Horton
Feb 01, 2011 20:18 |  #10
Noise can be eliminated. Motion blur cannot. There is always a trade. If noise bothers you, try two things. First, send for prints and see if you care after that. Big prints. Like 24 wide. Second, get noise reduction into your post processing, starting with the features in the modern Camera Raw versions. If you really want to control noise in post, get Noiseware or similar software.
:cool:
stayhumble
Joined Nov 2010
Feb 01, 2011 20:21 |  #11
was focal length already mentioned? if not, i would bet you might be shooting at 200mm or something far.
There are no rules for a good photograph and there are no excuses for a bad one.
SELLING:40D, 50D, 10-22, Tamron 17-50 non VC, 5D, 14MM II, 24-105, 70-200 f/4 IS, 430EX, 530EX (ALL MINT W/Box)
eelnoraa
Feb 01, 2011 21:03 |  #12
The first one looks like camera shake to me. The 2nd one focus to infiniti, so close subjects appear blurry.
This particular lens is not known for razor sharp, but from what I have seen, it is not too bad. I for one don't recommand 17-40L on crop body. There are better optic lens for less money or more features.
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
Hartley
Feb 01, 2011 22:52 as a reply to  @ eelnoraa's post |  #13
Wow - Lots of responses - thanks all!
xarqi, the daylight shot (from October) has a cheap UV filter (Promaster?), the recent sunrise has a much better B&W multi-coated ultraclear protection filter.
I have a Rocketfish carbon-fiber tripod with a Manfrotto 322RC2 head - not exotic, but pretty steady (and heavy - not for backpacking!)
The sunrise was shot at 35mm, the daylight rim view at 20mm. I do shoot at the other end a lot, but not this time..:)
I do understand getting the shutter speed up - I realized the clouds are blurred from motion as soon as you mentioned it & I thought about it - while they don't move perceptibly, frames just seconds apart show definite change - a good clue I should have paid attention to. So I need to move the ISO up and use a faster shutter speed for sure. That might mitigate the wind, etc. motion issues. (and yes, it was windy at sunrise) I do use the 2-second delay feature so my fat-fingering doesn't lead to shake..:D
I use Lightroom, and I really like the de-noise tools in it - I didn't use it on these pictures because I didn't want to muddy the water regarding resolution.
Thanks Again - you've given me much food for thought!
Hartley J
themadman
Feb 02, 2011 00:26 |  #14
The issue might be lens/camera combo.
15MP on a APS-C is still pretty dense and the 18-200 isn't the sharpest knife in the drawer (of lens in the bag if you get my analogy). The denser the sensor the harder it is on lenses.
Are those crops at 100% or past 100%? Any image past 100% will look unsharp.
In general, I wouldn't worry too much how a photo looks super cropped. As long as it looks fine at the size you want to print (or display on your computer) then it is ok :)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
DetlevCM
Feb 02, 2011 02:19 |  #15
18-200 lens -> I'd suspect the lens is the culprit.
Allround lenses will always have a weakness and will never be a real substitute for several lenses over the same focal lenght.
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
4,003 views & 0 likes for this thread, 18 members have posted to it.
1084 guests, 115 members online
