Thread started 01 Feb 2011 (Tuesday) 23:08
1Ds 2 actuation count, help needed
mikinla
Feb 01, 2011 23:08 |  #1
I am trying to determine actuation count for 1Ds 2 from raw (*.cr2) file.
in adobe photoshop, i can use file-> file info to get this info from
raw file in a line [aux:ImageNumber:36578​]. i assume this is about 36k
actuations. however, when i use 1Dcount I got a difference number. for
this case i get over 100k. of cause i also get a something like:
Raw tag data in hex: 1c18a280000000000. I don't know which one to
believe. anyone has answer for the question or have a better method
to determine the number
:lol:_______________
Canon 5D II, 50mm/f1.8,430EX,70-200/4L IS
sheawyatt
Feb 01, 2011 23:16 |  #2
mikinla wrote in post #11760486 (external link)
The photoshop ImageNumber goes up to 65536, and then starts counting again. I bet 1Dcount gives you 65536+36578 = 102114. 1Dcount is correct.
EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
Marketplace Feedback: Link
www.sheawyatt.ca (external link)
adamo99
Gallery: 6 photos
Feb 01, 2011 23:29 |  #3
You cannnot reliably determine the shutter count on the 1DII series. Any settings copied from one camera to another copies the shutter count over also.
mikinla
Feb 01, 2011 23:37 |  #4
sheawyatt wrote in post #11760529 (external link)
exactly. in abobe i got 36368 and in 1Dcount i got 100904
36368 + 65536 = 100904
Thanks a lot, this is why I have seen so many low actuation counts 1Ds 2 in ebay
buyer beware.
this is great information. every one is in the market for 1Ds 2 should know it.
mikinla
Feb 01, 2011 23:43 |  #5
adamo99 wrote in post #11760591 (external link)
however, this time sheawyatt nailed it. at least if you got 65536*n + AN = 1DN
AN = abobe image number;
1DN = 1Dcount number;
then you might get a right actuation number
Thinkdiesel
Feb 02, 2011 00:11 |  #6
www.camerashuttercount​.com (external link)
mikinla
Feb 02, 2011 00:45 |  #7
thanks. this site gives the same results as 1Dcount. but it is good to be double check
the results
adamo99
Gallery: 6 photos
Feb 02, 2011 07:55 |  #8
Now try copying the setting from another 1-series, and see what you get. :)
mikinla wrote in post #11760644 (external link)
mikinla
Feb 02, 2011 09:49 |  #9
adamo99 wrote in post #11761959 (external link)
how do you copy the settings from one to another? is anyone can confirm this? does this mean that
anyone can fake 1Ds 2 actuations if he knew how to do it and want to do it?
shutterrelease
Feb 02, 2011 10:08 as a reply to  @ mikinla's post |  #10
Yes. And it is very easy to do. Save settings on card. Put that card on second body. Use saved settings from card. Your second body will have same shutter count as first body. The only reliable way to check shutter count is to send it to Canon.
1D2N, 1DS2, 5DII, 5D MkIII
Rudix
Gallery: 18 photos
Joined Dec 2004
Apr 17, 2011 23:13 |  #11
Yes, unfortunately this is true, just had a 43K 1DSmk2 go to 2.8K.......
3,631 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is Miss Understood
529 guests, 162 members online
