Thread started 02 Feb 2011 (Wednesday) 06:26
24mm f/1.4L and 35mm f/1.4L - What's the difference
TijmenDal
Feb 02, 2011 06:26 |  #1
I am by no means an expert on photography; I know more than the average person on the street, but on this forum I'm pretty sure I'm with the 3% biggest noobies. N
othing wrong with that as I just started this (way too expensive) hobby, except for me buggering you with, probably stupid, questions.
I've been checking these forums a lot lately and learned a lot (high five for learning!), but there's some things I just don't understand. This being one of them:
Why would you buy either the 24mm or 35mm? They have the same specs, one has just a tiny bit longer FL than the other.
Take two steps forward or back, and you have exactly the same image in your viewfinder. They both aren't really wide angle lenses, and to be honest, I wouldn't know what type of photography they're suited well for. It's just that I'm wondering why you would buy one or the other, as taking a step forward or back will yield the same result.
The ónly thing I can come up with why you would get one is for the bokeh, because with one you'd be relatively closer to the object than the other, resulting in a slightly different bokeh.
Someone enlighten me please.
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
tomme
Feb 02, 2011 07:10 |  #2
if you mean the 24L mk2 its weather sealed and probably better coating.
the 11mm is actually pretty big different in focal length since its on the wide end.. i would have choosen the 24L for crop camera ( that just me though ). you could set your kit lense to 24mm and see how you like that, then set it to 35mm and see if you like that better.
Instagram (external link)
tomme
Feb 02, 2011 07:16 as a reply to  @ tomme's post |  #3
it also depends what you wanna take picture of, full body portrait, closer portraits, use it for indoor etc..
hieu1004
Feb 02, 2011 07:28 |  #4
I own both and the 24L II is a better lens, which is a given since it is a newer design. For a crop, I'd take a 24L since it gives the equivalent FOV as ~38mm on a 35mm camera format (35mm is roughly 56mm FOV).
The 11mm does not seem like a lot, but it is (to me anyway).
-Hieu
Gear | Blog (external link) | flickr (external link)
AntonLargiader
Feb 02, 2011 07:36 |  #5
TijmenDal wrote in post #11761698 (external link)
...one has just a tiny bit longer FL than the other.
For something that's a meter away, OK. For real-world things, they're not that similar. Frame something like a car or a house at 24mm, and see how far you have to back up to fit it into a 35. How about a landscape? :)
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
Spaniard
Feb 02, 2011 08:19 |  #6
The 24L MKII colors are better.
Derrick
Burn Money Project : Canon 5DMKII//24L MKII//50L//Speedlite 580 EXII.
TijmenDal
Feb 02, 2011 08:55 |  #7
tomme wrote in post #11761822 (external link)
That's what I did and I came to that conclusion. But yeah, I reckon when going bigger the difference gets a lot bigger really fast.
Thanks for the answers, though I'm still a bit skeptical on why someone would need both. I'm not contemplating buying either yet (or at all in the coming 10 years) but knowledge is power, eh?
//Tijmen
Gear
______________
flickrexternal link
_____________
Kento
Feb 02, 2011 08:56 |  #8
35L is sharper at f/1.4 then the 24L II. The 24L II still seems like the better lens. I use it a lot more often then my 35L.
My Tools
-Jesse
Unknown-Studio.com
Shadowblade
Gallery: 26 photos
Feb 02, 2011 09:02 |  #9
They have completely different focal lengths - you can't replicate the different perspectives just by changing your position.
bpark42
Feb 02, 2011 09:56 |  #10
-24LII is better in the corners.
-24mm is significantly wider than 35mm. This is especially apparent on full frame.
-It is often not as simple as "taking a step forward or back" to get similar framing.
-Even with similar framing, the perspective will be different. This will be especially noticeable when close to the subject.
bpark42
Feb 02, 2011 09:57 |  #11
Spaniard wrote in post #11762048 (external link)
Can you back this up?
m.shalaby
Feb 02, 2011 10:00 as a reply to  @ bpark42's post |  #12
Neither!!! Get the Sigma 30mm 1.4!!! :mrgreen:
hieu1004
Feb 02, 2011 10:01 |  #13
mdgrwl wrote in post #11762546 (external link)
About time you saw the truth. :cool:
-Hieu
mattjns93
Feb 02, 2011 10:02 |  #14
Even so, the 35L is no slouch in the color department. I figure it's a matter of a slight boost of saturation/vibrance to even it out.
5DII | 17-40L | 35L | 85L II | 50 1.8 | 430EX | flickr (external link) | Facebook (external link) (Please like it! :D)
Follow my photoblog of my study abroad in Florence! (external link)
m.shalaby
Feb 02, 2011 10:02 |  #15
hieu1004 wrote in post #11762551 (external link)
I thought that would get your attention... :p
8,289 views & 0 likes for this thread, 23 members have posted to it.
1059 guests, 104 members online
