Thread started 02 Feb 2011 (Wednesday) 12:16
printer powered up ??
kdvincent
Feb 02, 2011 12:16 |  #1
Do I keep my printer turned on all the time.
Canon Pro9000 II
Keith
Keith, Canon 7D, 5D, 5DMII, 30D,
bunch of glass, lights and modifiers
hawkeye60
Feb 02, 2011 12:19 |  #2
I don't.
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
ChasP505
"brain damaged old guy"
Feb 02, 2011 12:21 |  #3
Good question. I think it largely depends on the printer, but dye ink printers have far less clogging problems than pigment ink printers. I turn my HP dye ink printer off every night, but I also print something every day... even if it's just a test pattern.
Chas P
ncjohn
Feb 02, 2011 22:19 as a reply to  @ ChasP505's post |  #4
For what it's worth, a Canon person told me they recommend the 9000 be turned off every day or so because it cleans the heads when you turn it on but if you print every day or so there's no need. FYI, it also cleans the heads every time you open the top cover that gives access to the cartridges.
ChasP505
Feb 03, 2011 12:46 as a reply to  @ ncjohn's post |  #5
Equally important is HOW you turn it off. You must use the power switch on the printer itself to ensure that it goes through its shutdown routine and the "capping station" properly seals the cartridges.
You can't just turn off the power source or pull the plug.
Chas P
kdvincent
Feb 03, 2011 13:11 |  #6
thanks (I think).
1,144 views & 0 likes for this thread
Latest registered member is LoDesertWolf
827 guests, 227 members online
