Thread started 02 Feb 2011 (Wednesday) 18:44
Soft Case for Canon 800mm?
MikeV99
Feb 02, 2011 18:44 |  #1
Any suggestions for a well padded soft lens case that could be used with the Canon 800?
Thanks.
Mike
-- Mike -- The older the boy, the bigger and costlier the toys!
:) My Gear List :)
Fiddlefingers
Feb 03, 2011 02:56 |  #2
Lowepro Lens Trekker 600 AW II Backpack takes the 800mm without the camera attached. Actually I've just checked and it looks like the 800mm is only around 3 inches or 7.5 cm longer than the 500mm. If this is the correct then the 800mm with a camera attached should fit in this backpack with the hood reversed. My 500mm with TC and camera attached still has loads of space left.
http://products.lowepr​o.com …%20600%20AW%20I​I,2118.htm (external link)
http://www.tomgilland.​co.uk (external link)
Canon ­ Bob
Feb 03, 2011 03:32 as a reply to  @ Fiddlefingers's post |  #3
I use Kinesis long lens cases for my 600/4 and 300/2.8. The L521 will take the 800/5.6 with body attached if the hood's reversed. The cases have an excellent protection to weight ratio.
http://www.kgear.com/s​tore/index.php/l/l521.​html (external link)
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
MikeV99
Feb 03, 2011 06:45 |  #4
Thanks guys. The consensus is either the Lowepro Lens Trekker 600 AW II Backpack or the Kinesis Long Lens Case L521. The Lowepro comes with removable shoulder/waist straps. Best I can tell is that they have to be purchased as separate items with the Kinesis.
Mike
:) My Gear List :)
Canon ­ Bob
Feb 03, 2011 08:21 |  #5
MikeV99 wrote in post #11768398 (external link)
..... Best I can tell is that they have to be purchased as separate items with the Kinesis.
Yes, they do.
Bob
MikeV99
Feb 27, 2011 07:44 |  #6
Fiddlefingers wrote in post #11767923 (external link)
Can the harness be removed?
:) My Gear List :)
MikeV99
Feb 27, 2011 07:45 |  #7
Canon Bob wrote in post #11768003 (external link)
Bob
If you were buying one would you get the L521 or L620?
:) My Gear List :)
MikeV99
Mar 01, 2011 19:33 |  #8
Carry strategy for 800mm in the field.
In discussing this issue with a friend that also has an 800mm I realize that my real problem is needing something to carry the lens safely on a hike when I do not want to carry it while it is on a tripod.
I have a Think Tank belt, a small TT backpack, a Cotton Carrier, a Vested Interest vest, a small vest, and so on. I can also pull my transport case with the 800mm inside if the area permits. I use one of them depending on the situation. However, none of those setups would safely allow me to carry an 800mm in the field. My thinking was that a lens case might work in addition to these setups.
What do 800mm owners do when in that situation?
Thanks.
:) My Gear List :)
MikeV99
Jul 18, 2012 06:27 |  #9
Kineses
[L511] Compact Long Lens Case 500
Item Selection
L511a = L511 + Y515 Strap, but w/o A257 Pouch
L511, L511a or L511b 1 $146.00
[H130] Long Lens Case to Harness Adapter Strap H130 1 $0.00
[H245 or H250] Padded Shoulder Harness
Size Selection
H250 Medium/Large
H245 or H250 1 $43.00
[B106, B107, B108, B109 or B111] Kinesis Black Belt
Size Selection
B109 X-Large
B106 etc. 1 $33.00
Subtotal $222.00
Shipping & Handling $12.00
:) My Gear List :)
3,537 views & 0 likes for this thread
Latest registered member is angkorphoto
874 guests, 364 members online
