When you scroll through your wheels, what is your increment for Shutter + Aperture.
I have it set to 1/3 stops for both...But sometimes I forget what is actually a full (native/standard?) stop.
| POLL: "Shutter + Aperture set up." |
1/3 stops | 61 84.7% |
1/2 stops | 7 9.7% |
1 stops | 2 2.8% |
Other | 2 2.8% |
C.Michael Senior Member 754 posts Likes: 2 Joined Jul 2010 Location: Adelaide, South Australia More info | Feb 02, 2011 21:27 | #1 When you scroll through your wheels, what is your increment for Shutter + Aperture. www.christophermorrison.com.au
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Feb 02, 2011 21:33 | #2 Probably the most commonly accepted convention for the "normal" series would be:
stickshift Senior Member 533 posts Joined Nov 2009 Location: Missouri More info | Feb 02, 2011 21:38 | #3 C.Michael wrote in post #11766831 When you scroll through your wheels, what is your increment for Shutter + Aperture. I have it set to 1/3 stops for both...But sometimes I forget what is actually a full (native/standard?) stop. One click of the wheel will then be 1/3 a stop. I just count clicks. 7D, 5D mark II
AndersÖstberg Goldmember 3,395 posts Likes: 3 Joined Nov 2003 Location: Sweden More info | Feb 03, 2011 01:36 | #4 |
C.Michael THREAD STARTER Senior Member 754 posts Likes: 2 Joined Jul 2010 Location: Adelaide, South Australia More info | Feb 03, 2011 02:38 | #5 Anders Östberg wrote in post #11767776 What "other" is there? If people are using Nikon, or have a different method... www.christophermorrison.com.au
C.Michael THREAD STARTER Senior Member 754 posts Likes: 2 Joined Jul 2010 Location: Adelaide, South Australia More info | Feb 03, 2011 02:40 | #6 xarqi wrote in post #11766850 Probably the most commonly accepted convention for the "normal" series would be: f/1, f/1.4, f/2, f/2.8, f/4, f/5.6, f/8, f/11, f/16, f/22, f/32, f/45, f/64, etc. 1s, 1/2s, 1/4s, 1/8s, 1/15s, 1/30s, 1/60s, 1/125s, 1/250s, 1/500s, 1/1000s, 1/2000s, etc. Edit - sorry - I may have misunderstood your question. Nope, that is what I was getting at! stickshift wrote in post #11766879 One click of the wheel will then be 1/3 a stop. I just count clicks. True, cheers! www.christophermorrison.com.au
Delija Goldmember 1,095 posts Joined Jan 2009 More info | Feb 03, 2011 04:32 | #7 Yes,there's a formula, but knowing it isn't really important - what matters is knowing that a FULL F-stop lets in twice or half the light of the next f-stop (depending on whether you are opening or closing the aperture. Wow, what a nice picture! You must have a really great camera!
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Feb 03, 2011 04:54 | #8 C.Michael wrote in post #11767882 Nope, that is what I was getting at! I see that the Shutter values are exponential, is there some sort of formula for the aperture? True, cheers! Not exponential, geometric - there is a factor of 2 (with a bit of creative rounding applied in places) between each shutter speed value.
C.Michael THREAD STARTER Senior Member 754 posts Likes: 2 Joined Jul 2010 Location: Adelaide, South Australia More info | Feb 03, 2011 06:35 | #9 Delija wrote in post #11768126 Yes,there's a formula, but knowing it isn't really important - what matters is knowing that a FULL F-stop lets in twice or half the light of the next f-stop (depending on whether you are opening or closing the aperture. Some common f-stops are not full (like f 1.8, 3.5, etc). If you want to know the actual formula, it's simple enough - it's a relationship between the focal length of the lens as compared to the diameter of the aperture - divide the focal length by the diameter of the aperture and that gives you the f-stop - For example, if the focal length is 100mm, and the aperture is open to 40mm, then the f-stop would be f-2.5 - which is not a "full stop" since full stops begin at f-1 and f-2.5 would not be a number that would allow in half (or in theory, twice) the light of any FULL aperture starting with f-1 - if the focal length is 100mm and the aperture is open to 25mm, then the f-stop would be f-4 - (a full stop) and so on. The numbers are not linear like ISO - (ISO of 400 is twice as sensitive as ISO 200 and half as sensitive as ISO 800) - they are derived with a more complex formula to determine half and double the light. My examples of f-3.5 and f 2.5 and f 1.8 are stops that exist as 1/3 stops - Which seems to be the most common way lenses are marked - although I've never seen a lens with ALL the 1/3 f-stops marked on the lens barrel. F 1.8 and f 3.5 are very common, I don't know if I've ever seen f 2.5 (maybe because it just looks so close to f 2.8 which is a full stop and lens barrels have a limited amount of room)??? I suppose it would be easy to have the LED display in the modern viewfinders calculate exact apertures, but it's not really important - what's important is knowing if the exposure is correct. Peace, D. Thanks for taking the time to explain that! xarqi wrote in post #11768151 Not exponential, geometric - there is a factor of 2 between each shutter speed value. In the case of the f ratio (casually termed "aperture"), the factor is the square root of 2, ~1.414, with a bit of creative rounding applied. It's like this because when you double the diameter of the aperture (in the true sense), the amount of light transmitted goes up 4-fold, since the cross-sectional area has gone up 4-fold. To increase the transmitted light 2-fold, the diameter must go up by a factor of root 2. Hmmm, shows how rusty I am on maths. www.christophermorrison.com.au
kendon Senior Member 839 posts Joined Jul 2010 Location: germany More info | Feb 03, 2011 06:43 | #10 C.Michael wrote in post #11768375 Thanks for taking the time to explain that! Very enlightening - Although I still feel a little confused about the focal length v aperture. i think it's better explained the other way around: focal length / f-stop = pysical opening of the lens 7D, EF-S 10-22, EF-S 17-55, EF 70-200/4 IS, NiftyFifty, 580EXII, Σ 30 EX DC, Walimex 8mm Fisheye, MD Rokkor 50/1.4, BendyCam
Beanie'sDad Senior Member 581 posts Joined Nov 2008 Location: Irvine, Scotland More info | ^^^ Nice simple rule of thumb - like it! 5DIII, 5DII, EF24-105, EF 70-200 f4L IS, EF 85 1.8, "Sigmalux" 50 1.4, EF 35 f2, EF17-40 f4L
JOSX2 Senior Member 627 posts Likes: 4 Joined Jan 2011 Location: Mebane, NC (meh-ben) More info | Feb 03, 2011 08:57 | #12 xarqi wrote in post #11768151 Not exponential, geometric - there is a factor of 2 (with a bit of creative rounding applied in places) between each shutter speed value. actually...it's a factor of 2 between each stop of a shutter speed...not between each speed value (w/ the camera set in 1/3 stops). It'll be three clicks before the shutter speed is doubled from the original speed. website: Jim O'Sullivan Photography
Delija Goldmember 1,095 posts Joined Jan 2009 More info | Feb 03, 2011 14:41 | #13 C.Michael wrote in post #11768375 Thanks for taking the time to explain that! Very enlightening - Although I still feel a little confused about the focal length v aperture. Sorry - maybe it would have been more clear is I had added three words to "focal length" in my example of 100mm focal length - that should have been "focal length OF THE LENS"... Wow, what a nice picture! You must have a really great camera!
AntonLargiader Goldmember More info | Feb 03, 2011 18:01 | #14 1/3 stop... but now that you mention it, I might set to half stops. Image editing and C&C always OK
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | josullivan79 wrote in post #11768878 actually...it's a factor of 2 between each stop of a shutter speed...not between each speed value (w/ the camera set in 1/3 stops). Quite so. Given the context of the listed series though, I think the meaning was pretty clear. & further explanation on the creative rounding...it's applied to shutter speeds that aren't doubled/halved evenly. Thanks.
| Latest registered member is IoDaLi Photography 1732 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
