So since my Meike RC7 isn't triggering the new version of the YN-560, I want to try with a sync cord. What is the cable I need called?
3 pin something - female pc sync cable?
Feb 04, 2011 02:21 | #2 Seriously can't anyone help?
Lotto Goldmember 2,750 posts Likes: 192 Joined Mar 2005 Location: Southern California More info | Feb 04, 2011 03:38 | #3 I am not aware that anyone make such cable that directly connect the two ports, but you can try using the cable that comes with the trigger, and a adapter to convert the mini plug into PC plug. 5D, 24-105L, 70-200L IS, 85mm Art, Godox
Feb 04, 2011 09:40 | #4 Thanks, I've read at least one review stating it works fine with the 560 but I suspect that is the old model with the plastic foot. Maybe I won't bother trying a sync cord, at least I can use the Meike with my 468 or as a wireless RF camera shutter trigger
dedsen Goldmember 2,580 posts Likes: 34 Joined Aug 2006 More info | Feb 04, 2011 10:48 | #5 So this trigger has a proprietary connector and did not come with any cables? That would be very lame!
bruceq Member 108 posts Joined Feb 2010 Location: NE Pennsylvania More info | It is a propietary plug but it comes with cords.... just not a cord to go from this plug to a pc socket. Cameras - 5D MkII/Grip, 7D/Grip, T1i/Grip
Begin by replacing the adapter pictured above with a PC-to-hot shoe adapter.
dannyss Member 127 posts Joined Apr 2008 More info | Feb 04, 2011 14:27 | #8 I've got the same triggers. It is a proprietary connector. My idea: use one of the supplied cables that ends with the 1/4" plug and then get a 1/4" male to PC connector like this one:http://www.flashzebra.com/pics/nikonscrewlockradio.jpg 1D MK IV, 24-105mm L, 15mm, 50mm f1.8II
| Latest registered member is zachary24 1398 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
