Hi guys,
Not sure if anyone of you guys have had this problem, but my 85mm II's panel near the AF/MF switch has cracked sunk in slightly, and it creaks slightly when I switch between AF/MF, which I always do since the DOF is so thin.
Switch still works though, and the lens performs flawlessly except for the slight niggle.
Was wondering if anyone has actually replaced the panel before? I shoot sports so water resistance is an issue here.
Thanks!
Actually 85L makes probably a perfect combo with a 300L2.8 .. same type of DOF, micro contrast, colors depth ... and AF is perfectly accurate for many type of sports (dog agility, motor races, ... any tracking sports)
