Two nights ago, the night was clear, so I decided to take some photos of Cygnus. The lens was at 38mm and the exposures were 15 seconds and it was on the widest aperture at f/5.6 and ISO 1600.
The first image below shows what one of the lights were like so then you can see what I had to put up with.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
IMG_6000
After stacking 34 light frames and 27 darks, and using Iris to deal with image processing. I only need to do a few clicks and get something reasonable. I ended up with the following:
scalecygnus020211
I have noticed that in DSS if you apply the changes, then you have something that you cannot work with at all. Comments and criticism are appreciated. I have tried to use Photoshop for image processing, but it took me hours and I got worse results than when I used Iris with a few clicks.
Thanks,
Naddie
