Thread started 04 Feb 2011 (Friday) 14:39
The cost and part number for 5D MK2 AA Sensor Filter
augenblick
Feb 04, 2011 14:39 |  #1
For those in the know can you kindly provide me the cost of and the number for 5D MK2 Anti Aliasing Sensor Filter in the case I screw up my wet cleaning of beloved camera.
I have used eclipse and the pecpads with proper sized plastic swab.
rtist2g
Feb 04, 2011 14:43 |  #2
As far as i know, you can't purchase the AA filter. That would be a trip to service, and a huge bill. I wouldn't worry too much though, as i've cleaned sensors about 50 times and have never scratched an AA filter. (BUT there's always the possibility i guess)
nickcollura.com (external link) | Facebook (external link)
Canon • Glass • Speedlites • Strobes • RRS • 
augenblick
Feb 04, 2011 17:08 |  #3
Thanks but I need this info, has anyone done it?
Glenn ­ NK
Feb 04, 2011 17:16 |  #4
I don't have this information, but I did screw up the filter on my 30D a few years ago, and was replaced by a knowledgeable camera repair shop (authorized Canon repair shop).
This is not something you can do yourself, the reason being that it's extremely difficult to not get "almost invisible" particles of dust trapped on the sensor surface when you remove and replace the filter.
And those "invisible" specks of dust will be very visible at f/16 or smaller. And they cannot be cleaned out without starting all over - and getting some new dust specks in.
As the saying goes, "do not attempt this at home".
Glenn
When did voluptuous become voluminous?
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Feb 04, 2011 18:10 |  #5
the filter doesn't have a seperate part number, which means you'd be in for a whole cmos sensor assembly.
Part number is CY3-1595-000 (cmos sensor ass'y w/o FB data) or CY3-1595-100 (cmos sensor ass'y with FB data)
edit: found the FB data bit is in reference to Flange Back Offset values, presumably a very accurate measurement of the actual part concerned so repair techs can replace a sensor and shim correctly without having an expensive piece of measuring kit.
Apart from dust issue which isn't as bad as Glenn's mentioned above, there's no reason why someone with a bit of skills couldn't replace a filter.
Come to think of it, while doing an IR conversion I stripped the screwheads on my 10D filter and had to take a drill to it to get it off...
TF posting: here :-)
Glenn ­ NK
Feb 05, 2011 00:37 |  #6
Just to clarify:
The filter was replaced on my 30D - not the sensor - they come separately. I would suspect that this is true for the 5DII, but may not.
The shop that replaced my scratched filter did a good job for the most part (they are a Canon licensed repair shop for warranty purposes).
Note the words "for the most part". This means that when I shoot at f/22 I can see a dust spec that no amount of wet cleaning has been able to remove.
I've concluded that the shop managed to include one small speck of dust.
The hard part is keeping dust out.
You might get lucky - or not.
Glenn
augenblick
Feb 05, 2011 08:09 |  #7
Thanks for the responses. According to this place it is a seperate part & costs $300 !!!!
http://www.lifepixel.c​om …php?m=product_d​etail&p=67 (external link)
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Feb 05, 2011 16:27 |  #8
the filter itself is a part that can be removed, it's just Canon don't list the filter for 5D MK II as a seperate part.
3rd parties like Lifepixel etc source the glass itself (rather than the filter in it's holder)
3,061 views & 0 likes for this thread, 4 members have posted to it.
1264 guests, 170 members online
