Thread started 05 Feb 2011 (Saturday) 17:26
What Calibration Kit to Get?
crazyfoo88
Joined Sep 2004
Feb 05, 2011 17:26 |  #1
Have been looking around for a few weeks and can not make up my mind!
I have 2x Dell U2311 Monitors.
90% of my editing is done for WEB ONLY. Only 10% or so are print, so I am looking more for proper colour profiles for internet use.
Budget is 250 >
What out there is good for what I am looking for?
My Flickr (external link)
ChasP505
"brain damaged old guy"
Feb 05, 2011 17:39 |  #2
There are only 3 complete kits that I would suggest:
X-Rite EyeOne Display 2
Datacolor Spyder3 Elite, vers. 4
Datacolor Spyder3 Pro, vers. 4
Any one of these will do a fine job for what you're describing, but the spyder3 Pro software is limited for setting luminance level.
Chas P
crazyfoo88
Joined Sep 2004
Feb 05, 2011 17:54 |  #3
ChasP505 wrote in post #11783983 (external link)
Okay, I know this monitor is wide gamut and I want to make sure the software can create the profile correctly. Would the Pro V4 hinder this?
ChasP505
Feb 05, 2011 18:21 |  #4
crazyfoo88 wrote in post #11784086 (external link)
It's NOT a wide gamut monitor, but it does cover sRGB. But if you DID have a wide gamut monitor, the Spyder3's would be my recommendation.
Chas P
crazyfoo88
Joined Sep 2004
Feb 05, 2011 18:31 |  #5
My bad, then what should my action plan be?
ChasP505
Feb 05, 2011 18:42 |  #6
crazyfoo88 wrote in post #11784261 (external link)
Eeny meenie minie moe? Rock paper scissors?
All will do a great job. But if you need to hit a specific target luminance value... unless you're very experienced with calibrating monitors, the Spyder3 Pro should be your last choice. If you are very familiar with the tricks of using Spyder3 software, it may be your first choice.
Chas P
tim
Light Bringer
Feb 05, 2011 18:49 |  #7
This one (external link).
bohdank
Feb 05, 2011 18:54 |  #8
It's not very hard to get SP3 Pro to measure the luminance, and therefore change it to whatever level you want.
sssc
Gallery: 32 photos
Feb 05, 2011 21:14 |  #9
Glad i read this. Price of Monitor. And sp3. MMMM. Just how hard is it to Calibrate. This is coming from someone with NO EXP
Keith-EOS R 7D MarkII EOS REBEL T2i 18-55,55-250.85 1/8. 100-400L. 10-22 f/3.5-4.5. 24-105mm f/4L IS,70-200 II,RF 24-105
bohdank
Feb 05, 2011 23:24 |  #10
Take your time, read everything on every screen before moving forward, read whatever Manual comes with it. It's really not very difficult. A question you may/should have is what luminance to set it to. 90-120, depending. You might start at 120 which may seem pretty dim if you are not used to it (I have mine set to 100) but that's because most people have their monitors set to way to bright and manufacturers usually ship the monitors with the luminance set to max, around 300.
The idea is to get the monitor "brightness" to match your prints, imo. It will never be the same since prints are reflective light and monitors are transmitted light but, eventually you'll find a happy balance.
Let us know how it goes.
Indecent ­ Exposure
Feb 06, 2011 02:41 |  #11
If the Pro does everything you'd need, is there any reason to get the Elite?
- James -
www.feedthewant.com (external link)
500px (external link)
Gear List and Feedback
drdiesel1
Gallery: 86 photos
Feb 06, 2011 05:32 as a reply to  @ Indecent Exposure's post |  #12
I use X-Rite's Color Munki. It's a complete system and work very well.
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
ChasP505
Feb 06, 2011 11:17 |  #13
Indecent Exposure wrote in post #11786502 (external link)
Of course not. If 120cd/m2, 6500k, and 2.2 gamma are the calibration parameters you want, it's fine. But if you're an advanced user and need custom settings, the Spyder3 Pro comes up short.
If you're a total beginner, stick to the default presets in Spyder3 Pro.
Chas P
JakAHearts
Feb 07, 2011 12:50 |  #14
Just curious why you are spending all this effort. Do you have a large online customer base that will view your work with calibrated monitors?
Shane
tonylong
...winded
Gallery: 60 photos
Feb 07, 2011 13:24 |  #15
JakAHearts wrote in post #11795119 (external link)
You have no control over how an image will appear on other peoples hardware, but if you are calibrated to a "standard" you have several adantages: you know that people who also have calibrated systems and color managed software will come close to seeing things the same way, you will be able to go from one color managed app to another in your system and have things reasonably consistent, and last but not least if you have a color managed flow with printing, you have the best chance of your prints reasonably matching your screen. This can be extended to working with external labs/print shops who provide tools to manage your printing process.
Is it work? Sure. Is it absolutely guaranteed? No, because there is too much variety of monitors, with many people viewing using "consumer" monitors which won't cooperate very well and only a few using top-of-the-line professional monitors (and editing environments) with a huge price tag but very accurate. Then, there is a lot of (most in fact) photo viewing software out there that is "dumb" when it comes to color management. Plus, there is a big "variables factor" in printing -- printer, paper, ink and software processing that can be tough to factor in.
So, as to whether it's worth it, well, all we can say is we ave people here all the time who complaing because their colors "don't look right" either after saving an image and opening it in "some other software" or in print or whatever. Some of this is to be expected, but some can be helped along by good color management. It's up to you whether you care!
Tony
3,757 views & 0 likes for this thread, 10 members have posted to it.
1191 guests, 174 members online
