Thread started 06 Feb 2011 (Sunday) 15:59
Digital Sensor Sizes
kjonnnn
Feb 06, 2011 15:59 |  #1
http://www.cambridgein​colour.com …al-camera-sensor-size.htm (external link)
Great Article on Sensor Sizes ...
Excerpt ...
Similarly, the focal length multiplier relates the focal length of a lens used on a smaller format to a 35 mm lens producing an equivalent angle of view, and is equal to the crop factor. This means that a 50 mm lens used on a sensor with a 1.6X crop factor would produce the same field of view as a 1.6 x 50 = 80 mm lens on a 35 mm full frame sensor.
Be warned that both of these terms can be somewhat misleading. The lens focal length does not change just because a lens is used on a different sized sensor — just its angle of view. A 50 mm lens is always a 50 mm lens, regardless of the sensor type. At the same time, "crop factor" may not be appropriate to describe very small sensors because the image is not necessarily cropped out (when using lenses designed for that sensor).
Tapeman
Sliced Bread
Joined Jan 2004
Feb 06, 2011 16:18 |  #2
Bigger is better, just like with film, larger pixel sites have lower noise and more dynamic range.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
952 views & 0 likes for this thread, 2 members have posted to it.
1060 guests, 103 members online
