Should I buy a 24-105L for my 5d? I do portraits and weddings. If I do should I sell my tamron 28-75? Is it worth it?
unlimited6986 Senior Member 866 posts Joined Sep 2007 More info | Feb 07, 2011 05:55 | #1 Should I buy a 24-105L for my 5d? I do portraits and weddings. If I do should I sell my tamron 28-75? Is it worth it?
Fiddlefingers Member 195 posts Likes: 1 Joined Dec 2008 Location: Scotland More info | Feb 07, 2011 06:00 | #2 Some people will tell you that the 24-70 f2.8 is better for weddings due to the extra stop of light. I think that attitude is slightly dated since with the 5D Mk II you can bump up the ISO and still get clean images (up to 1600 anyway). With the 5Dc 800 ISO gives acceptable noise.
MOkoFOko nut impotent and avoiding Geoff 19,889 posts Likes: 22 Joined Jun 2010 Location: Michigan More info | Feb 07, 2011 06:04 | #3 Yeah, most everyone will tell you to get the Canon 24-70 2.8. Truthfully, you can work wonders with the sigma 24-70 2.8, Tamron 28-75 2.8, and Tamron 17-50 2.8... if you're on a budget. Perspective clients DO take your camera gear into consideration. It doesn't hurt to have plenty of expensive L-lenses and primes
JeffCS Member 37 posts Joined Dec 2010 More info | I would agree that the 24-105 f/4 may not give you enough speed in low light situations on a 5D especially for weddings. I have used the 24-105 for quite some time on a 5D and more recently on a 5D Mk II and it is an excellent quality lens. For portrait work I usually switch to the 70-200 f/2.8. Since the 5D Mk II produces much lower noise files than the original 5D at higher ISO's I find that I can keep the 24-105 on the Mk II in lower light situations and still get high quality files. MOkoFOko offers good advice. Good luck! Jeff |http://www.jeffsagar.com
MGiddingsPhotography Senior Member 964 posts Likes: 10 Joined Mar 2010 Location: Norwich, Norfolk, UK More info | Feb 07, 2011 14:54 | #5 The 24-105 is fine for weddings. Loads of wedding photographers use them.
| Latest registered member is Monkeytoes 1372 guests, 188 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
