Hi guys,
I am working on a project that's involving several P&S cameras, upwards of 8.
The most cost effective solution was to go with canon A530 or A540 as I need them to run CHDK. Problem is when I put in a SDHC card I get a memory card error upon boot up. A quick google turns up that the A530 only supports SD cards which only have a capacity of 2 gigs.
I require a few more gigs due to them running a timelapse type of setup in which I cant change out the cards.
Is there any possible way to get a SD card that has more then 2 gigs? or a way to get more capacity out of the camera?
Open to any suggestions!
Thanks!
