Just what does it mean when photo caption states 100% crop? How do you know when it's 100%?
Thanks!
JamesEmory Senior Member 857 posts Joined Nov 2009 Location: Bay City, MI More info | Feb 07, 2011 09:44 | #1 Just what does it mean when photo caption states 100% crop? How do you know when it's 100%? James Emory
Vladimer Senior Member 634 posts Likes: 14 Joined Dec 2009 Location: Alberta, Canada More info | Feb 07, 2011 09:49 | #2 If you are in an image edition program and you view the image at 100% or 'actual size'. That is 100% crop.
Feb 07, 2011 09:58 | #3 Vladimer wrote in post #11793982 If you are in an image edition program and you view the image at 100% or 'actual size'. That is 100% crop. Generally if you were to upload this for comparison to a website or forum it would be massive as most pictures are a few thousand pixels across. So to show a 100% 'crop', you view it at 100% or actual size and then just crop down the image so its 800px across (for example) and effectively cutting off all that extra image around it so when you upload it or view it on a forum its not 4 screen lengths wide. You are basically viewing a small portion of the picture. Hope that made some sense =/ Sort of. Sounds like something I shouldn't be concerned with as a hobbyist. Thanks. James Emory
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Feb 07, 2011 10:27 | #4 James Emory wrote in post #11794046 Sort of. Sounds like something I shouldn't be concerned with as a hobbyist. Thanks. It has meaning only if you want to illustrate a point you are making in a forum - showing something that can best be seen at full image size because down-sizing would alter or conceal it, like noise or sharpness. Elie / אלי
I think I understand now. I view my image at 100% and then crop what I want to illustrate from that view and do a "save as" if I want to keep/file it. Am I correct? James Emory
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Feb 07, 2011 10:46 | #6 Am I correct? 100% Elie / אלי
Feb 07, 2011 10:50 | #7 tzalman wrote in post #11794294 100% Thank you! James Emory
tonylong ...winded More info | Feb 07, 2011 12:48 | #8 Yeah, it's not that compicated; when you think of the equivalent viewing term "1:1" as mapping one image pixel to one display pixel to best view qualities like fine detail and noise or the effects of noise reduction and sharpening (on the fine detail), then if you want to display those things on the Web for analysis by others you crop a portion of that view that would fit into your normal viewing screen. Tony
| Latest registered member was a spammer, and banned as such! 2707 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
